Indicator stalk with headlight switch?
From northern 'burbs adelaide
Im in the process of tidying up my 1200 ute ... the thought has crossed my mind to fit an indicator assembly with a headlight switch built in and do away with the pull switch
Has anyone done something like this before and what did you use for the donor assembly?
Posted on: 2015/11/11 9:01
Re: Indicator stalk with headlight switch?
HYP014 at one time was experimenting with a Bluebird multi-switch, dunno how it turned out
http://datsun1200.com/modules/myalbum/photo.php?lid=14806
Posted on: 2015/11/11 9:47
Thats a cool setup
Posted on: 2015/11/11 9:57
From Townsville, Qld
Pretty sure Ian's coupe is running the bluebird switch to, or possibly a sunny one as he'd use those for the steering boxes
Posted on: 2015/11/11 21:53
From Brisbane
I'm using indicator and wiper switches out of a Silvia. They came with the half cut for ca18 so I was able to use the Silvia dash wiring.
Posted on: 2015/11/11 23:11
From sydney australia
You could use Sunny, or N12 Pulsar has intermittent wiper position, which could be a bonus. You just have to make up some intermediate wiring to go from the loom to the switch. You even get a hazard warning switch.
Posted on: 2015/11/12 7:07
From MOOROODUC. Victoria
Plus 1 for the Silvia, I used the Silvia s15 stalk and replaced the 1200 wiper motor with the Silvia one.... intermittent wipers. The Silvia wiper motor fits onto 3 of the 4 bolts.
Posted on: 2015/11/13 9:59
