Intercooler Ca18det 1200 Ute
Hey guys, after some advice on what intercooler to run in my Datsun 1200 ute.
running ca18det.
and will be running alloy s13 radiator with twin thermos. I would like a intercooler that tucks in behind the grille and not been seen from the bottom?,
What intercoolers are you guys running, Measurments Ect. And Pictures. would be very helpful, thanks In advance
Posted on: 2016/1/13 5:00
Re: Intercooler Ca18det 1200 Ute
From Brisbane
Its been a while since I installed mine but from memory it is about 520x220x60mm. It is just a cheap ebay cooler. Its pretty tight in there and i should have really trimmed a bit of the valance to bring it forward about 10mm for clearance to the radiator - the hoses just rub on the radiator and i have no room to move the radiator back.
jpg  post-27386-0-13182800-1353831595_thumb.jpg (22.19 KB)
7166_569607c19b90f.jpg 400X299 px
jpg  IMG_0612.jpg (54.37 KB)
7166_569607dbd6626.jpg 800X598 px
jpg  IMG_0621.jpg (77.67 KB)
7166_569607e8e90f5.jpg 800X598 px
jpg  IMG_0626.jpg (69.15 KB)
7166_569607f369151.jpg 800X598 px
Posted on: 2016/1/13 7:45
Edited by ___1200ute on 2016/1/13 8:12:48
Edited by ___1200ute on 2016/1/13 8:16:54
Edited by ___1200ute on 2016/1/13 8:17:15
With an S13 radiator in a 1200, between the radiator and the grille, you can fit an intercooler maximum size of:
* about 26" TOTAL length
* about 12" high
* about 2.5" thick
This one is 9" x 26" x 2.5" and fits there
Posted on: 2016/1/13 7:48
http://datsun1200.com/uploads/newbb/10276_556fe5bcf0b55.jpg
rx3 or rx7 radiator is the best because it puts the outlets in the best spot for the ca.. not too tight for the intercooler pipe... check my build
Posted on: 2016/1/14 5:19
From Brisvegas
i had a 280x300x76 cooler behind the grill
Posted on: 2016/1/14 12:16
1980 Datsun 1200 ute CA18DET
I have one around the size dd posted fits nice
Posted on: 2016/1/14 12:52
Car free
From New zealand
I'm installing mine ATM too.... I'm using a 450x300x70mm intercooler so far I have had to cut about 30mm out of the front lower apron out and grind back two spots on the grill to give a little clearance so the grill doesn't rub on the cooler ! I'll be running a custom cross flow radiator tho and will be moving the top hose outlet so it doesn't collide with the intake piping ...
Posted on: 2016/1/14 21:31
Be aware take care avoid life in a wheelchair
Dattos - 1200 ute 4agze, 1600 L18 twin Su, 1600 ca18det
Current - building a ca18det 1200 ute and drag 1200 ute undecided on the donk !
From Port Douglas. QLD
Hey,
I used an aeroflow unit from eBay. its matt black and you can't see it behind my grill. I also used a stock ca18det radiator with twin SPAL fans to make it all fit. i can't find a pic but its all pretty tight. Im in the tropics and the stock super thin ca18det s13 radiator does a great job of keeping it all cool.
Posted on: 2016/1/19 5:31
1200 ute
ca18det
Quite a regular
From Aberdeen, UK
In my old S13 back when i was still using the CA, I had a saab intercooler. I remember it being pretty thin which could be handy.
Posted on: 2016/1/19 17:00
