best place to get oversize a14 pistons?
From Leeton NSW
Hey there chasing some oversized pistons for an a14 anyome know of any forsale or point me in the right direction to someone who sells them?
Posted on: 2016/3/7 12:31
Get in, sit down, shut up and hang on!!!
Re: best place to get oversize a14 pistons?
All piston companies sell them. They are usually custom order but a few companies have off-the-shelf items
For example:
* Mahle
* Sealed Power
* JE Piston
* JP Piston
* Federal Mogul
* Ross Racing Pistons
* Arias Piston
* CP Piston
* PAECO
* Venolia
* Wiseco
* HP Engineering
Posted on: 2016/3/7 23:25
From Brisbane, Australia
Last A14 I built in the early 90s used some sort of Mitsubishi piston - looks like it was a G32B piston. 76.9mm, 33mm Comp ht and 19mm pin. It was about .040" oversize for the A14 and with .020 or .030" (.5-.75mm) milled off the crown - really just the outer edge to get the comp height down. Trawl through an ACL catalog... Way cheaper than getting stuff made.
Posted on: 2016/3/9 12:28
Edited by L18_B110 on 2016/3/9 22:09:36
Edited by L18_B110 on 2016/3/9 22:13:55
Edited by L18_B110 on 2016/3/9 22:32:01
Look into the ca16de piston. I've got a set here and at 78mm they look like a good cross fit for the a14/15. They have a slight dome that would need to be milled for whatever c/r was needed.
Strong piston too with drilled oil returns instead of slotted. Also have full floating pins. Obviously a performance piston even though it's not forged. Clearance will be more than a slotted piston but less than a forged so the durability would be good too.
I returned a new set of ca16 from ebay because they were slotted. So probably only OEM or good drilled aftermarket if they're out there.
Posted on: 2016/3/11 2:53
From Townsville, Qld
I got my +60 thou ones through precission international New vs old pic added.
Posted on: 2016/3/11 5:06
One of the best places is Brprojects, in-stock, easy ordering, arrives in the post. http://www.datsun1200.asia/category/select/cid/260
A14 79mm piston kit by Kameira
Not a huge selection, but might as well go big
Posted on: 2016/3/11 5:43
From Leeton NSW
I found a company that sells pistons to suit a mini minor motor still a series motor not going to go to extreme probably only +030 bigger.. im not very mechanically minded just going off what the huy building my motor is telling me hahha thanks
Posted on: 2016/3/17 0:07
That isn't going to work.
The largest BMC A series used a 70.6mm bore.
Datsun A14 is 76mm bore.
I just bought the Mitsubishi pistons and ring set for $100 locally. Good quality ACL Duralites :) mmmm shiney!
jpg  4G32B piston 4KRY2705-020.jpg (89.79 KB)
518_56e9fbe180107.jpg 977X768 px
Posted on: 2016/3/17 0:30
Going .030" over is not worth it. You have the expense of machining, yet the +0.73 mm bore is only a gain of [correction:] 27 cc
As long as your paying to machine the block, go with +3 mm oversize (gain of 110 cc)
Posted on: 2016/3/17 1:38
Edited by ddgonzal on 2016/3/17 3:13:16
I assume he just wants to recondition his engine, rather than really modify it. I imagine not every block will take 3mm over-bore anyway.
I'm doing a budget modified engine and wouldn't bother trying to stretch it 3mm! I chose these 1.4mm oversize (76.9+0.50=77.4mm) because that's the cheap, readily available piston option here, gives about 1450cc and the basically flat top piston (after milling) ups the CR to work better with a cam grind.
Posted on: 2016/3/17 2:44
