Browsing this Thread:   3 Anonymous Users
« 1 ... 39 40 41 (42) 43 44 45 ... 49 »
Re: Turbo EFI A12 for under $1200. Discussion thread
From Adelaide
A group buy might be an option if anyone's got time to organise it. Let Simon iterate a few more times though.
This might be a bit off topic right now but:
Getting custom parts cast is not as expensive as it used to be, CSIRO Clayton have in their advanced manufacturing facility a machine that 3D prints resin fixed sand molds. Alternatively getting the manifolds 3D printed in a suitable material (stainless steel) may work out alright to, especially if you want to fill the full build volume. The CSIRO machine achieved something like 95% density which was pretty cool. Go have a look if you ever get the chance. There are a bunch of places that offer metal 3D printing now.
Posted on: 2016/3/16 7:49
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
dont know why I thought you had a H145!
excellent just the box then is the only issue
Posted on: 2016/3/16 16:40
From Moorebank
Sorry reading another post, but still interested in the injection kit
Posted on: 2016/3/16 20:38
From Ballarat Victoria
Wound the boost up a little with Ziggy here yesterday. Just to 24Psi. it made 136.3Kw and 118Nm. We also set up a pressure sensor in the turbo manifold to check it V's inlet manifold pressure. The exhaust manifold pressure is 4.5Lb less than inlet pressure all the way through the range(once boost comes on).
This pressure differential gives me confidence to put a hotter cam in it. It cost $160 for cam and followers to be reground and $70 for new double springs. $250 all up, includes gaskets to do the job. I have it all here, so will swap them over when I get a chance.
Posted on: 2016/3/19 3:03
VIC DYNO HIRE
182hp out of a stock A12!!! My God why am I mucking around with sidedraughts....
Cheers
Dave
Posted on: 2016/3/19 3:36
interesting if thats an A15 with oval ports
If so the stock A12 still makes awesome numbers
for 300cc less capacity but maybe curve is less
steep on the A15?
Posted on: 2016/3/19 5:01
A15??? This is a stock A12 motor from eBay. Original round port head, head bolts, standard head gasket, inlet manifold etc. Just 1 injector pointing into the turbo compressor and a 40mm throttle body bolted to the original manifold.
Posted on: 2016/3/19 5:15
VIC DYNO HIRE
A15? I thought it was turbo A12 as the title states?
Posted on: 2016/3/19 5:18
It is. D must have thought we were playing with Ziggy's ute. If I was, I wouldn't be talking about it in this thread. I do at least try to stay on topic :)
Posted on: 2016/3/19 5:31
VIC DYNO HIRE
I thought yep Ziggies setup
A12 130+kws ??
just like a big fat pizza!
http://vidmg.photobucket.com/albums/v ... 0Part%203_zpsg5hbjyco.mp4
Posted on: 2016/3/19 10:14
Edited by D on 2016/3/19 11:15:31
Edited by D on 2016/3/19 11:16:11
