(1) 2 3 4 »
13B Rotary Swap
From St. Louis, MO
Hello guys, I finally decide to start with my Rotary project. I know is going to take me some time as I have to restore the car at the same car.
Will be asking couple of question about some modifications I want to do like
Need to convert my front strusts to coilover, bigger brakes with a Ford 4 1/2 pattern
The beginning of the car a complete factory 1200,
[url="http://s90.photobucket.com/user/PR_Xr ... psmlspqr8q.jpg.html"]Open in new window
[/url]
[url="http://s90.photobucket.com/user/PR_Xr ... pscgplp9w6.jpg.html"]Open in new window
[/url]
[url="http://s90.photobucket.com/user/PR_Xr ... psnth6xybk.jpg.html"]Open in new window
[/url]
[url="http://s90.photobucket.com/user/PR_Xr ... psyyarmvff.jpg.html"]Open in new window
[/url]
I started by removing the factory A12 to make room for the Mazda 13B Turbo.
[url="http://s90.photobucket.com/user/PR_Xr ... psluwfk5uf.jpg.html"]Open in new window
[/url]
[url="http://s90.photobucket.com/user/PR_Xr ... pscz12ogty.jpg.html"]Open in new window
[/url]
[url="http://s90.photobucket.com/user/PR_Xr ... pso0tdbsxa.jpg.html"]Open in new window
[/url]
It will be injected using a Microtech LT10x4, a complete ProJay intake set up with 8 1600 injectors.
[url="http://s90.photobucket.com/user/PR_Xr ... psb5ma60zt.jpg.html"]Open in new window
[/url]
[url="http://s90.photobucket.com/user/PR_Xr ... psrapvqnym.jpg.html"]Open in new window
[/url]
Front suspension will come from the guys at MadDat and their 13B kit, also using their adjustable Lowe control arm. Struts will be modify and use the T3 coilover system and their camber plate. The front brake has become an issue, this is my hurdle as of today!
[url="http://s90.photobucket.com/user/PR_Xr ... psfnjwq0ec.jpg.html"]Open in new window
[/url]
[url="http://s90.photobucket.com/user/PR_Xr ... psy70hescl.jpg.html"]Open in new window
[/url]
[url="http://s90.photobucket.com/user/PR_Xr ... psdougm5cn.jpg.html"]Open in new window
[/url]
The rear end will also be swap to a Ford 8.8, will eliminate the c-clip and change the end plata to a Big Ford. Axel will come from Strange Engineering and a set of Wilwood brakes to be able to keep the emergency brake. The wheels are RC Components 15x10 single beadlock using Mickey Thompson 26x12 tires
[url="http://s90.photobucket.com/user/PR_Xr ... psvxh8pikx.jpg.html"]Open in new window
[/url]
[url="http://s90.photobucket.com/user/PR_Xr ... pshxihljmx.jpg.html"]Open in new window
[/url]
[url="http://s90.photobucket.com/user/PR_Xr ... psgjpxvble.jpg.html"]Open in new window
[/url]
Rear suspension will consist of a custom ladder bar system and a set of QA1 single adjustable coilover
[url="http://s90.photobucket.com/user/PR_Xr ... psznma5j7l.jpg.html"]Open in new window
[/url]
Posted on: 2016/10/1 23:26
Edited by DogoX on 2016/10/22 4:18:38
Edited by DogoX on 2016/10/22 4:20:27
Edited by DogoX on 2016/10/22 4:21:08
Edited by DogoX on 2016/10/22 4:22:14
Edited by DogoX on 2016/10/22 4:43:37
Edited by DogoX on 2016/10/22 4:58:47
Edited by DogoX on 2016/10/22 15:03:02
Re: 13B Rotary Swap
Sounds good
The Datsun 1200 struts are already coilovers with a Ford 4.5 inch pattern (same as Mustang/Falcon). If you are thinking of 5-lug wheels, maybe you can use the Ford 5-on-4.5 discs which bolt onto some Nissan struts (see Brake Swaps#Ford), although many Nissans incuding S14 240SX uses the same bolt pattern
Using the 1200 struts mean lighter weight=faster performance. You can also convert them to adjustable spring height or convert them to small-diameter coils (useful if you will be fitting extra-wide front wheels)
Posted on: 2016/10/1 23:53
Re: 13B Rotary Swap
From St. Louis, MO
Hello guys, need some help.. I look over the wiki but couldn't get the answer.
Before I spend any money on my front brakes (waste) need your help. What options do I have When upgrade the front brakes?
I'll be using 15 X 4 wheels 5 lugs 4.5 ford bolt pattern
Any advise is welcome?
I thought of re drilling the factory hub to 5 lug..
Thanks in advance!
Posted on: 2016/10/10 2:15
Puerto Rico! Home of the fastes Rotary engine cars! Period
Re: 13B Rotary Swap
OPTION 1: PCD-converting wheels spacers are easiest way, works OK with high-offset wheels
eBay search
does not look possible to put 5-lugs in a stock hub
If you swap to B210/B310 struts
Looks like enough material to fit 5-lugs?
Until you turn the hub over
So it looks like a strut swap is best option?
OPTION 2: B310 ("Datsun 210") struts are same length as 1200, but are the larger 2" tube so your shock inserts choices are abundant. If you swap these onto your 1200, Ford 5-lug rotor-hubs from eBay bolt on. See B310 Strut Swap and Ford Brake Swap
OPTION 3: Maybe could swap S14 "240SX" 5-lug struts with 5-on-4.5" wheel bolt pattern. See S13 Strut Swap, should work IF S14 is similar. Uses 1200 struts with Datsun B310 lower control arms & ball joints
Posted on: 2016/10/10 6:38
Re: 13B Rotary Swap
From St. Louis, MO
Thanks for the advise.. Will be doing some research around to see if I can fin a B210 around.
I was also advise in using the Ford Pinto Hub/ disco brake. Has anyone done this route?
Posted on: 2016/10/10 21:41
Re: 13B Rotary Swap
I would not advise B210 parts
Posted on: 2016/10/11 0:56
Re: 13B Rotary Swap
From St. Louis, MO
Thanks, I send you a private message
Because of sourcing and comparing price, I'll probably buy a set of Wilwood or aerospace. Had a bit some issue before with aerospace(warping).
Will see if I can modify the Wilwood to fit.
http://www.wilwood.com/BrakeKits/Brak ... rd&model=Pinto&option=All
Posted on: 2016/10/12 19:42
Re: 13B Rotary Swap
B210 is different from Datsun 210. It's the 210 strut that documented swap for 1200s
For a budget street/strip car, S13 struts are better than Pinto suspension (lighter, and better brakes). Nissan S13 parts are easy to source in Missouri, it was a regular production car for USA: 1989-1994 Nissan 240SX
Missouri is also home to the winningest 1200s in the country (SCCA racers) including pjz who sells 1200 racing parts
Posted on: 2016/10/12 22:00
Re: 13B Rotary Swap
The Pinto front suspension swap is a very old swap. It is not the best, but it's tried and true
The "Pinto" brakes from Wilwood are a better idea:
* Light alloy hubs
* Extra light thin rotors
* alloy calipers
For drag racing, light is good
I have no idea if Pinto-spec hubs can be modified to fit a 1200.
Here's what a fellow club member has done:
Wilwood Dynapro single caliper and Wilwood 10.25" two-piece disc. Uses stock 1200 spindle and stock 1200 hubs
I finally got these struts on the car! Wow is all I can say! The pedal is rock hard and the car stops ridiculously fast! I haven't done any measured stops yet but the feel is outstanding.
Posted on: 2016/10/12 22:05
Re: 13B Rotary Swap
Im sure you understand the prices of rotary parts atm and near future?
its getting cheaper to go full billet plates the way things are going
South Africa has some cheap CNC places for a full billet 13b
stock non pollution early 1970s 13b weighs around 120kg
full alloy around 80kgs.
Id go for the recommended above to counter the heavier rotary
Posted on: 2016/10/13 5:08
Edited by D on 2016/10/24 4:57:00
(1) 2 3 4 »
