Has anyone done the VL commo auto swap?
From Rosewood, QLD
Interested to know how this conversion goes as I am looking to keep my sedan auto and add a little boost.
Posted on: 2017/1/13 16:08
1971 B110 sedan project.
2012 Nissan Micra daily.
Re: Has anyone done the VL commo auto swap?
From MOOROODUC. Victoria
so which Nissan auto is equivalent to the VL?
Posted on: 2017/1/13 21:28
The stock Datsun 1200 auto can handle a little boost. I would just add a transmission cooler
Cooler fittings are already there
Posted on: 2017/1/13 22:08
From Rosewood, QLD
Demacoz the VL jatco 4N71B is the 4 speed auto.
Posted on: 2017/1/14 1:32
4N71B is not necessarily any stronger than the 3N71B. It has an extra overdrive gear and lockup converter, neither of which add strength, they only lower the RPMs for highway cruising
Stock 1200 auto can handle 10 psi boost
Posted on: 2017/1/14 2:01
I haven't heard of anyone doing a 4N71B swap into a 1200
JATCO 4N71B sources
* 1984-1989 Chrysler, Dodge Plymouth (Mitsubishi)
* 1983-1989 Mitsubishi
* 1984-1989 Nissan Cars
* 1986-1989 Nissan Pick-ups, Vans
* 1984-1993 Mazda Cars
* 1988-1995 Mazda Trucks
* 1986-1988 GM VL with Nissan RB six-cylinder
Posted on: 2017/1/14 2:05
From melbourne
I have been contemplating this myself for the wagon. Got the 4N71B already . I aim to do it this year. Just cant decide what ratio for diff and color to paint. Im sure if it can handle a VL it can handle A14 S/C 10 psi boost
Posted on: 2017/1/14 4:07
the 4n71b was never offered as a light duty box as far as Im aware and sat behind in cars with over 200lbs of torque with no issues. There is a RE50RO5A 5 speed that could be adapted and run manually also but for the 4n71b best speak to KEAS they know the Jatcos well for rotaries, RBs, SRs and even Geminis that run over 500hp.
http://keas.com.au/products.php
JATCO 4N71B inc Rotary
Up to 450hp modified to suit various engine combinations
C omponents to suit rebuilders
Full manual forward pattern valve bodies
Engine braking in ALL gears
Transbrake forward pattern valve bodies
VASCO Plus input & intermediate shafts sets
Billet intermediate servo/piston sets
Billet over-drive servo/piston sets
Cast alloy pans
Shift kits
http://www.prnd.pl/uploaded/images/skrzynie_all_1.jpg
the 5 speeds are smaller lighter than the old 4 speeds
but the ecu is in the valve body so to eliminate that
and convert to full manual you need an expert but maybe
very worthwhile if you want an efficient auto
Posted on: 2017/1/14 4:18
4N71B is a 3N71B (same gears and all) but with a middle section added for the overdrive assembly
The "duty" depends on the specs. For example: Turbo models have more clutch plates and larger clutch pistons, but are still labeled 4N71B Automatic
With the 3N71B, the 1200 version had 3 low-gear clutch plates, while the 280Z version had 5 plates to handle the higher torque
Some say L4N71B was light duty, but it actually means:
* L4N71B - Lockup torque converter
* E4N71B - Electronic-control lockup torque converter
Posted on: 2017/1/14 5:00
Edited by ddgonzal on 2017/1/14 5:16:48
The biggest problem I foresee with a 4N71B swap is slower acceleration. All the torque converters are made for larger engines, so the A12/A14 won't spin it up very far. The gears are exactly the same ratios (1st, 2nd, 3rd) so no advantage there
Solution: For adequate initial acceleration, use a stiff rear diff gear, maybe 4.625 out of Datsun 1000 Ute. With the .686 overdrive it'll still run lower revs on the highway compared to a 4-speed manual with stock 3.9 gear
You could also order a custom torque converter for a small engine (the stock 3N71B converter can't be used in a 4N71B due to the lockup interface). This will help greatly with take-offs, but not with accelerating the car once at road speeds
Best combo might be:
* Custom medium-stall converter for low-torque engine
* 4.11 gears from Datsun 1000
* 4N71B with overdrive
Posted on: 2017/1/14 5:35
