someone has to buy this datto v8 original
Posted on: 2017/2/14 12:56
Re: someone has to buy this datto v8 original
From Adelaide
It's beautiful! I already have too many projects though.
Posted on: 2017/2/14 19:51
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
That's cheap!
Posted on: 2017/2/14 23:01
would make a very plush family car has some awesome features
for that year the nissan Y40 v8 had low 9.0:1 compression
197 hp (195 bhp, 145 kW) @5000 rpm and 237 lb·ft (323 Nm) @3200 rpm
with more comp and mild reground cam probably a monster!
sad that no coupe versions were released with the y44 v8
one with metal skills could do it as a hakosuka alternative
Posted on: 2017/2/15 2:34
From Biloela, Sunshine State
I can barely picture that ey. It would look mad as with a hakosuka front and a worked motor. I wonder if there would be room for a turbo?
Posted on: 2017/2/15 2:49
these engines are windsor copies very narrow
lots of space aeround bay especially is u use
modern power steering and air con compresssor
also ver wide wheels tyres and bolt on guards
makwes it weven harder to imagine :} xy gt killer
Posted on: 2017/2/15 5:21
From Perth
Too early for me
I want a H252 with Y44e
Posted on: 2017/2/15 10:06
love them both but the panels on the H150 are just that bit thicker heavier
also h252 reminds me too much of my older better built 280 mercs from side on
http://i138.photobucket.com/albums/q2 ... imports/blog/lowride1.jpg
and lines are less pimp on H150 more jetson 60s than seedy 70s disco etc :)
Im just a 60s X-gener
http://www.damnjdm.com/apps/blog/show ... the-nissan-president-h150
Posted on: 2017/2/16 2:29
If that's what you're after you could go for a 1968 Datsun 1600 v8 swap. Has all the nice angular looks and the beautiful v8 music. Lowered and slightly tubbed?
Posted on: 2017/2/16 2:53
From Snohomish, WA USA
No Presidents in Japan. Wonder if Trump would ride in that. I would if he would.
Posted on: 2017/2/16 5:40
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Eaton M62 SC 10 lbs. Boost / 150hp Progressive Nitrous
Ford 8.8 Posi/4.11
