Air conditioner in a 1200
From St. Louis, MO
Hello guys,
Has anyone installed an air conditioner in a 1200? I know it was a factory accessory back themand are hard to find.
Looking for some ideas on under dash units ..
Thanks in advance
Posted on: 2017/9/14 15:38
Re: Air conditioner in a 1200
Still for sale new. Summit Racing in USA sells a $1300 generickit which contain compressor and everything needed except engine mounting brackets and V-belt. Can get a 1200-specific kit from Acqua Garage out of Japan for $3000. eBay sells $500 universal kits with China-made compressor and condensor.
Posted on: 2017/9/17 1:22
From Las Vegas USA
A/C was semi common in B210s; you might be able to find one of those, they were an add on as well. The later model 210s commonly had them but I believe those were a specific application.
Realistically if you did find an older unit in working order there would still be the issue of the old systems used R12 so likely better to just go with a kit that uses R134 or whatever is current
Posted on: 2017/9/17 21:24
apart from the engine bracket Im sure you could retrofit any late 70s unit
also found on old corollas, honda civics and other american cars
If you get your hands on an old blower and A series bracket your are set.
Also could use later compressor from a later car instead will be more
efficient for parasitic drag losses as bearings and seals are newer.
Posted on: 2017/9/19 1:29
From Adelaide
The old systems can be retrofitted with different throttling valves for the R134a assuming it's not a capillary tube system. I had this done on an old car (91). Worked fine.
Posted on: 2017/9/19 8:29
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
