Browsing this Thread:
1 Anonymous Users
what diff to get |
going to put a 600 hp rotary motor in a 1200 and dont want to tub it out,whats diff can i use that can take that power without breaking axles and is easy to install without cutting the car.Any help would be appreciated
Posted on: 2001/12/2 9:47
Re: what diff to get |
From Invercargill, New Zealand
A shortened 9" diff - easiest if find one already engineered for RX 3 as it should bolt up.
Posted on: 2001/12/2 9:52
Roccos performance used a S3 bluebird locker in their 13b turbo 1200 which was a potential 9 sec car! S3 trx diffs/axles have a reputation for their strenght.
Posted on: 2001/12/3 9:03
Not too shy to talk
I just read in ZOOM with the white 4agze powered ute, that he used a C20 LSD 4.1:1 van diff center in a TRX Bluebird diff and axles. Has anyone heard of or done the convert? Mely
Posted on: 2001/12/3 9:34
if thats the case, then stick with the ute housing and put a S3 centre in and leave the axles coz the ute ones are the same size as the bluebird ones coz they use the same bearings. Justin
Posted on: 2001/12/4 5:56
