what diff to get
going to put a 600 hp rotary motor in a 1200 and dont want to tub it out,whats diff can i use that can take that power without breaking axles and is easy to install
without cutting the car.Any help would be appreciated
Posted on: 2001/12/2 9:47
Re: what diff to get
From Invercargill, New Zealand
A shortened 9" diff - easiest if find one already engineered for RX 3 as it
should bolt up.
Posted on: 2001/12/2 9:52
Roccos performance used a S3 bluebird locker in their 13b turbo 1200 which was a
potential 9 sec car!
S3 trx diffs/axles have a reputation for their strenght.
Posted on: 2001/12/3 9:03
Not too shy to talk
I just read in ZOOM with the white 4agze powered ute, that he used a C20 LSD 4.1:1 van diff center in a TRX Bluebird diff and axles. Has anyone heard of
or done the convert?
Mely
Posted on: 2001/12/3 9:34
if thats the case, then stick with the ute housing and put a S3 centre in and leave the axles coz the ute ones are the same size as the bluebird ones coz they
use the same bearings.
Justin
Posted on: 2001/12/4 5:56
