(1) 2 3 »
Which A-series engine is best for a hi rev/power engine?
Quite a regular
From San Diego, California USA
I have been wondering which engine is the best 1980's+ A-series engine. I see a lot if people talking about A12 and A14, but not much A15. Which would be better: A12, A14, or A15?
Thanks
Posted on: 2004/8/19 19:46
Re: Which A-series engine is best for a hi rev/power engine?
From Feilding, New Zealand
i have an A12 in my SSS cam, factory headers and twin 40's. also an A15 out of an early 80's C20 van with a mild cam carb and extractors it has smooth power though the range with heaps of torque. but then it all comes down to what you can afford.
Posted on: 2004/8/19 20:26
From Coondle, WA Australia
well as far has high revs, the shorter the stroke, usually the faster and higher the rev, hence why as a general rule smaller capicity motors rev harder and faster, thought not always the rule. Acording to that theory and a12 will rev a little harder than an a14/15. Their highest revs are about the same,(6000rp,) but the a12 would probally get there faster. (the shorter stroke)
power, you mean torque, then an a15/14 is the go.
An a12 can go just as well as an a14/15, but you have to spend a little more money on it to do so. (its about 10hp less in standard form i think, 81hp to 72 from memory).
But bigger, better, faster more. is a simple rule that will always bring good results.
Posted on: 2004/8/19 23:06
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Quite a regular
Thanks for the reply, I guess I can go with an A15 and have the thing Fully balanced after I tune it with the parts I want.
Thanks again
Posted on: 2004/8/19 23:26
From Little Rock, AR
Yep the shortest stroke will give you the easiest and best revs. I know you're not talking stock so that 6000rpm figure someone threw out there is not an accurate figure of redline. All the A series rev really great when built right, but the A12 has the max potential for highest revs. Best way to go to get the best of both worlds is a big bore A12. One of the popular racing engine choices involves mixing and matching A12 and A13 parts, but I'm not sure exactly what. The A14/15 will give you the most torque and power though, so I'd go that route personally if you were sticking to A series.
Posted on: 2004/8/20 0:38
From WA
i'd go with the biggest engine possible - so yeah, the A15.
these little babies need all the help they can get in the "low down torque" department, and the extra rev-ability of the samller engine will be offset by the lower amount of torque it produces. this might make it a great power producer for it size, but be a pain in the proverbial to 'drive' the thing out of corners or get any decent speed out of it.
that's my happy meal with fries anyways...
Posted on: 2004/8/20 1:36
From Melbourne, Australia
im always amazed at how big the difference is between the a12,14 and 15, i have a decent a12gx setup and a mild a15, the a15 makes me feel like im driving a 6cyl compared to the a12, to get
the a12 to go fast I rev the crapper out of it and change gear as quick as possible, good for racing/rally
the a15 i dont take to max revs as it's not required and it pulls great after a nice smooth gear change, great for road driving
morale of the story.. what exactly are you looking to use the motor for???
Posted on: 2004/8/20 3:15
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Brisbane
I agree with 1200rallycar, the a15 you don't have to rev as hard because of the longer stroke (more torque) By far the best reving motor i have had is the one i am currently using in the rallycar at the moment, it's a big bore a15 with a knife edged crank in it (I machined two kilo's of the crank, 12 Kilo's down to 10 kilo's) added to a very light flywheel/clutch assembly this thing revs instantly, it's amazing!!
But it all comes down to the use of the motor and the budget.
Posted on: 2004/8/20 6:15
Quite a regular
I want to use the car for daily driving and take it out to the track once in a while (and a little drifting) I'd like to keep up with my friends (One has a stock 1990 Nissan 240SX and the other has a now overbore 1.8L hi-comp 4AGE in his 1986 Toyota Corolla GTS)
Posted on: 2004/8/20 7:00
From South Africa, Bloemfontein
I may be wrong, but I think to get enough power out of a A12 to keep up with these cars you will struggle with it as a daily driver.
Rather then go A15 with less mods to keep it drivable as a daily car.
the A15 will also give you better power out of corners than the A12.
What do you guys think?
Posted on: 2004/8/20 7:46
1977 Datsun 1200GX
(1) 2 3 »
