Re: wiring tacho
From Sydney, Australia
The CA18 will not have a single coil, so the diagram may not be of much help for this fella. It's certainly possible to get the tacho to work. I did with the stock CA18 ECU.
I used the common 12V wire that feeds all coils after the transistor pack. This line was cut and I ran wires under the dash to connect to the 2 tacho inductive loop spade terminals.
The downside is that if this connection is broken, you lose power to the coils, and the engine will obviously stop working.
Cheers,
Chris.
ps. I vaguely remember the wire colour was solid red, but I'd need to check on the weekend. It's basically a common wire to all 4 coils (so all pulses run through the tacho loop), and I had used cheap spade connectors.. that's why I know the engine stops working when the link is broken.
Posted on: 2004/9/23 1:09
Subject Poster Date
     wiring tacho skdmrx 2004/9/22 21:40
       Re: wiring tacho DiscoStu 2004/9/22 23:00
       Re: wiring tacho dattodude 2004/9/23 1:09
         Re: wiring tacho skdmrx 2004/9/23 1:27
           Re: wiring tacho dattodevil 2004/9/23 6:54
             Re: wiring tacho skdmrx 2004/9/23 20:55
