wiring tacho
hi guys. i just wired up a ca18 into my 1200 coupe but im having trouble with my tacho any advice would be great
Posted on: 2004/9/22 21:40
Re: wiring tacho
From Birchip, VIc , Australia
This Diagram should help. Tacho Wiring Diagram
Posted on: 2004/9/22 23:00
If you get a lemon, remember to ask for the tequila and salt!
Re: wiring tacho
From Sydney, Australia
The CA18 will not have a single coil, so the diagram may not be of much help for this fella. It's certainly possible to get the tacho to work. I did with the stock CA18 ECU.
I used the common 12V wire that feeds all coils after the transistor pack. This line was cut and I ran wires under the dash to connect to the 2 tacho inductive loop spade terminals.
The downside is that if this connection is broken, you lose power to the coils, and the engine will obviously stop working.
Cheers,
Chris.
ps. I vaguely remember the wire colour was solid red, but I'd need to check on the weekend. It's basically a common wire to all 4 coils (so all pulses run through the tacho loop), and I had used cheap spade connectors.. that's why I know the engine stops working when the link is broken.
Posted on: 2004/9/23 1:09
Re: wiring tacho
thanks.ill try it out and get back to you
Posted on: 2004/9/23 1:27
Re: wiring tacho
From Christchurch. NZ
place a resistor parallel to the coil power feed if you get a break in the tacho cicuit it will still power your coil.
Posted on: 2004/9/23 6:54
Re: wiring tacho
it works!!!!!.i used a blue and red wire that i found just before the plug that goes to the coils.ill try the resistor soon.
Posted on: 2004/9/23 20:55
