1200 Top Speed
Not too shy to talk
From CO, USA
Roughly what top speed could a stock 1200 be taken to?
Posted on: 2004/10/14 16:23
Re: 1200 Top Speed
From Townsville
Well my totally stock 1200 coupe peaks out at 75mph.... on a very long straight road...
Posted on: 2004/10/14 18:41
Re: 1200 Top Speed
From Feilding, New Zealand
a road test put the SSS's top speed at about 86mph (138kph).
Posted on: 2004/10/14 19:09
Re: 1200 Top Speed
From Las Vegas USA
At SCCA drivers school back in 1990 the engine was bone stock except header. Running on 185/60 13's the car did 88 MPH - boy did I get passed. With standard brakes I thought it was plenty fast enough.
Tom
Posted on: 2004/10/14 19:39
Re: 1200 Top Speed
From sydney
Back in the late eighties I would go down the long straight on Mona vale road and the stock coupes speedo would almost reach the ton.
I cant say how fast it was really going,it seemed pretty fast to me and it was as fast as I could make it go.
Posted on: 2004/10/14 23:01
Re: 1200 Top Speed
From Toowoomba QLD
My stock ute would get to 160 kph, just, with my hands wrapped firmly around its neck.
Posted on: 2004/10/14 23:19
Re: 1200 Top Speed
From Burbank, CA
got my A15 210 up to 94 mph pretty easily. Different final drive gearing would change the top speed.
Posted on: 2004/10/14 23:48
|||\ 81 KPB310 /|||
Re: 1200 Top Speed
From Sydney, Australia
Stock Wagon with original A12.
6600rpm (digital tacho) in 4th.
Valves were bouncing..
About 92mph. After calculating on paper.
It's hard to know how much the little tyres would expand when being driven at that speed. So it might have been a touch faster.
Posted on: 2004/10/15 2:04
Re: 1200 Top Speed
You guys really need to read the Datsun 1200 FAQ section!
Top Speed
I would guess the top speed is about 90 mph (144 kmh). The speedometer error in the test vehicle was 7% off. It read out faster than the actual vehicle speed. This inflates speed, fuel mileage and distance traveled (if you go by the speedometer). My first 1200 speedo was off about 10%. My current speedo is off ~7.5%.
The FIA docs states a top speed of 140 kmh, and 150 kmh for the high-compression [GX] engine.
To test the top-speed you need a long (5-mile) track or a banked oval. Mechanix Illustrated tested a stock but broken-in 1200 in 1973 on the Daytona Speedway:Quote:
topping out at a shade over 90 mph
MOTORMAN magazine out of New Zealand tested both a regular 1200 and a 1200 SSS and note this:Quote:
We didn't take the 0-90mph time with the standard car because it was near the Datsun's top speed, but the SSS version took half a minute to reach this velocity, and continued to pull strongly to its maximum of 100mph.
Posted on: 2004/10/15 4:38
Re: 1200 Top Speed
From WA
i pipped 100mph out of my A12 (later found out it had a stengthened bottom end) but that was with a tailwind, 15in rims, slight dowhill and a rod thru the block when i backed off.
Posted on: 2004/10/15 6:12
