« 1 2 (3) 4 »
Re: a15tt to drag at calder this friday night (5th nov)
From Newscastle, Australia
Yep its a flywheel me thinks....
Posted on: 2004/11/3 22:06
Dont die wondering.....
From Melbourne, Australia
thanks fellas!!!!!
just got inspired by the comments , and me and me mate just popped the motor and box out, and the flywheel bolts were finger tight
guess that was the problem, it's all reassembled and dropped back in the car, just gotta wire and plumb everything back up tommorow...
...ready for the drags tommorow night!!!!!
YAY, YIPEEE, WOOHOO
Posted on: 2004/11/4 5:38
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
RC I hope you put Loctite on those bolts before you put it back in......
Posted on: 2004/11/4 5:42
From Brisbane, Australia
good stuff 1200RC!
its nice when the problem isn't as bad as first feared, especially when it means you can make it to the event after all! Have fun...
Posted on: 2004/11/4 6:25
From Ballarat,Australia
flywheels are ground
in a flywheel grinder btw.... :)
the right type of loctite that suits the application is a must also
yes have seen the 'old flywheel come loose trick' myself :)
Posted on: 2004/11/4 6:38
www.cortina-mk1.com
CA18 det powered :)
From Melbourne, Victoria
try not to wreck my future engine 1200rc.
cheers :)
Posted on: 2004/11/4 6:48
From WA
ah man! i really wanted those turbos too...!
err...i mean...yeah...good job.
nah, seriously - glad it wasn't terminal. nothing worse than having just built something and thinking you've just gone and stuffed it by doing something simple - like missing a gear change or forgetting to refill the gearbox with oil or having the speedo cable still hanging and have it catch in the spinning uni joints or...
Posted on: 2004/11/4 7:19
wooooot yehhhaaaa!!! good to hear, go hard chief.
Posted on: 2004/11/4 12:35
78 model datsun 1200 ute. A15 twin webbers, dogleg 5speed.
Jk Rubicon unlimited, 58 CJ3B Willys
rain bloody rain
drags cancelled, will do it soon though
Posted on: 2004/11/5 7:00
1200 Coupe Rallycar
From Christchurch NZ
Not trying to be bossy, but I hope that you replaced the flywheel bolts. I replaced mine with high tensile (12.9) capscrews. It also pays to run a tap into the holes first, and spray them with loctite primer, before blowing them out with compressed air prior to assembly.
I remember when mine came loose, only just got the blower going. Makes a god awful noise.
You can be forgiven for thinking that the motor had lunched itself.
How much longer til the next meet?
Posted on: 2004/11/5 19:10
Forced Induction!
« 1 2 (3) 4 »
