« 1 (2)
Re: URGENT HELP NEEDED!!!!!! WHAT SWAYBAR?
From sydney australia
no spare holes on the sunny,but use the crossmember from a a10 stanza for the same
result.
Posted on: 2004/12/6 9:59
From Christchurch NZ
result.
Good advise, but we didn't get stanzas in NZ.
Now what do I do?
Posted on: 2004/12/6 22:58
Forced Induction!
From Brisbane, Australia
A14force, as luck would have it, I'm about to buy another A10 Stanza and we won't need the engine x-member. Freight shouldn't be too much of a problem?
Posted on: 2004/12/6 23:28
From WA
A14force wrote:
pro-240c wrote:
what did you do yo make it work?
See the link to the photo from Harry.
i was asking Team_dat...i couldn't get the swaybar links to line up on a (to me) suitable angle but apparently it's not on too much of an angle when everything else is bolted up so it's okay.
Posted on: 2004/12/7 0:26
Could be the go, Do they bolt more or less straight up?
How similar, disimilar is the lower arm set up?
The other alternative is change the sump, and modify the 310 Xmember to take the larger motor. I'd probably have to completely remove the A sreies mounts from the member, (They look pretty flimsey) and make some new brackets to weld on.
Posted on: 2004/12/8 7:00
Forced Induction!
« 1 (2)
