Re: another brake problem
From Sydney , NSW
Just a thought .....
if you rebleed all four corners and all is still not well, bleed the master as well and try again. Usually only a problem if you have disconnected lines to the cylinder but I have had to bleed my m/c after caliper changes in the past. Worth a look.
Cheers
Posted on: 2005/3/1 21:04
Subject Poster Date
     another brake problem shaun 2005/3/1 9:40
       Re: another brake problem COUP1200 2005/3/1 9:46
         Re: another brake problem Dodgeman 2005/3/1 9:50
       Re: another brake problem ANGE 2005/3/1 9:54
         Re: another brake problem COUP1200 2005/3/1 10:12
           Re: another brake problem LAGWAGON 2005/3/1 10:31
             Re: another brake problem R-fastmotorsport 2005/3/1 21:04
               Re: another brake problem b310gx 2005/3/2 9:49
