to L or not to L
From south australia
what do you think about puting an L series in a 1200 as i was going to work my a14 i thaught it may be eaysyer to get the power out of an L series
how would i go for mounts what are the tricks of the trade for this and what HP rating does a standard L18 have i have also noticed that performance parts are much easyer to find for L series motors which is a real plus
any help is good help thanx guys
Posted on: 2005/3/26 10:02
Re: to L or not to L
any one???????????
Posted on: 2005/3/26 12:35
From Sydney
L18-b110 has been down the same road that you are considering. L18 has posted many threads on doing the conversion. Try the search option, im sure something will come up.
Posted on: 2005/3/26 12:45
From Perth Western Australia
I've (with the help of L18) written an article for the tech section on L series conversions, just waiting to get it in there...
If you want it, just supply me with your email...
Posted on: 2005/3/26 16:43
From Christchurch NZ
It's not really easy. Ive spent the last two days fitting an L20 into a 310. Ive had to modify the sump to get clearance on the steering arm. (It rises as the steering goes on lock) As well as lower the top of the Xmember.
An L18 will be easier as the aren't as tall, but it's all FUN and Games.
Posted on: 2005/3/26 21:54
Forced Induction!
so realy it might be just as easy to put a ca18 in then
my email is yzfr6@dodo.com.au
thanx guys
and i will try the search
Posted on: 2005/3/26 22:39
rb20
You have mail...
Posted on: 2005/3/27 7:16
thanx dazza its coming through right now slowly but shurly
Posted on: 2005/3/27 9:55
Hey A14force, did you try using a L16 sump on the L20?
From memory they are slightly different, when we threw a L20 in my mates 1600 we had to use a L16 sump as the L20 sump hit the crossmember.. Just a thought.
Posted on: 2005/3/27 13:45
The motor came out of a 1600. It had a "midsump". I chaged it for a "frontsump" from an 810. 90% of the hard stuff is done. now it should all be plain sailing. (Yeah right) Well maybe.
Posted on: 2005/3/27 21:54
Forced Induction!
