5 speed tranny identification (56k large pics)
hey guys, just picked this up at a salvage yard, they had it listed as a 4 speed but from looking this thing over it looks like a 5 speed dogleg, did i hit the jackpot??
http://pg.photos.yahoo.com/ph/captainbarkey@sbcglobal.net/album?.dir=/2dd5
Posted on: 2005/5/20 19:30
Re: 5 speed tranny identification (56k large pics)
Quite a regular
From Christchurch, New Zealand
As you've probably worked out it a 63 series, so guess you did.
Was the wrecker in Oz??
Posted on: 2005/5/20 23:49
naw central texas, was in a salvage yard on a shelf for at least two years. was advertized as a 4 speed so no wonder it sat there for so long!
Posted on: 2005/5/21 0:55
From Melbourne Vic
it is hydraulic clutch actuated tho... whats it for? is that a sutmpy box from an r30 skyline?
Posted on: 2005/5/21 1:55
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From Invercargill, New Zealand
No it's a 63A - hydraullically operated from the factory. It's a good option for you in the 1000 race car unless you have a Dellow 3T in there. Either box is unbreakable behind an A series - easier to get good ratios with the Toy box tho.
Posted on: 2005/5/21 2:59
From Perth Western Australia
stanza box isn't it? same as the one i have in the ute behind my L20b...
Posted on: 2005/5/21 5:36
From sydney australia
yes you've hit the jackpot.don't buy any lottery tickets,cause you just used up a years worth of luck.now,to mount it,find a 210 (b310) automatic gearbox crossmember,& with a little filing of the bolt holes,it should bolt straight in.it'll also drop the transmission down away from the tunnel.i've got an l18 & a 63a (must mean l series) in a b310 coupe,& thats what i used.now you just have to find a
tailshaft with the right spline.see if you can find a a10 tailshaft.i think they were called a 510 or a 1600 in america.or maybe the wrecker
still has the tailshaft that fits this gearbox.
Posted on: 2005/5/21 6:42
63A was common in the USA in B210s and larger cars (the 63A came with either L-series bellhousing or A-series pattern).
5-speed tech-section article
How did you determine that this is a 5-speed 63A and not a 4-speed 63A?
Posted on: 2005/5/21 7:04
From Millgrove Vic OZ
Length of the extension housing after the steel divider plate.
Posted on: 2005/5/21 11:23
Cheers Feral
this is going into a 1980 210 (b310) 2 door coupe a15 with an automatic. so i guess i'm good with the crossmember. i have combed the forums quite a bit but i'm still not sure of some things..
1. will i still need a new driveshaft? if so, does it need shortened and modified?
2. can i use the automatic flywheel? or do i need to get a matching one?
3. i think i saw a post where someone said i need to get a special clutch kit for this transmission versus a normal 5 speed? can anyone elaborate?
4. looking through the tech guide i see a reference to a 63A 4 speed but no further information on it, only a 63A 5 speed. nevermind on this, just manually shifted it, definitely a 5 speed.
i am pretty much a car novice but i hope to graduate to amateur by doing this ambitious swap
Posted on: 2005/5/21 14:45
