a15ett just loose flywheel bolts it seems
From Melbourne, Australia
got the motor out and the bolts were sitting a couple of threads out each,
will pick up new bolts, loc-tite em, and try to get the whole lot back in the car tomorrow, providing that was the only problem she could be back and running tomorrow
maybe another cruise in order boys?
GO THE MIGHTY A-SERIES
SHE'S BACK FOR ANOTHER SERVE OF PUNISHMENT
WHICH I WILL GLADLY GIVE HER
Posted on: 2005/6/1 12:13
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
Re: a15ett just loose flywheel bolts it seems
THANKS HEAPS A14force for suggesting that in the other thread
i could see myself with the head and sump off trying to work out the problem, and not even having checked that, but cause of what you said i checked that first and thats saved me a lot of dicking around!!! cheers mate
Posted on: 2005/6/1 12:19
1200 Coupe Rallycar
Hasnt this happened before to ya Mike?
Posted on: 2005/6/1 13:37
From Brisbane
Give ya self a upper cut Mike ....had all us 1200.com members worried .....But that is very good news dude!! Give it hell on the strip now
Ye of little faith.. takes more than twin turbos to kill the Aseries ...as long as there is oil they "keep on keeping"
Posted on: 2005/6/1 14:11
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
I too thought that this had happened to you before. Quite recently too, if memory serves. I seem to recall it resulted from an over rev during a missed shift.
If you clean the threads in both the bolts & the holes till they are sterile, then follow the loctite directions to the letter, & overtorque the flywheel bolts by about 5% you will help to keep those bolts in place.
Chris, the Boss at the local service station, overcame the problem after losing a couple of flywheels, with a custom made harmonic balancer, [see my photo album] & i will be using one on my coupe's engine. I believe that they also improve the level of smoothness in the running engine. At my age, i'm all for engines that run smooooooth while still delivering the goods.
Posted on: 2005/6/1 15:40
Love your Datsun.
Treat it well.
From Brisbane, Australia
good news - about time something went your way!
don't take it on a cruise - drive it nice and gently straight to a dyno or drag strip!!! I'm sure I'm not the only one that's interested to see some numbers...
Posted on: 2005/6/2 0:37
From Newscastle, Australia
Make sure you put loctite on the bolt head surface as well as the thread as well as torquing to 65ftlbs (60ftlbs is factory). That will keep them in.
Also what grade loctite are u using...they arent all the same.... Some are soft some more brittle depending on the torque load you require the bolts to hold down.
Posted on: 2005/6/2 0:47
Dont die wondering.....
From California
Yeah, and don't forget the locktite for those loose brain bolts
Posted on: 2005/6/2 1:14
if the brain bolts were loose would i have built this thing in the first place?
no loc-tite for them buddy
Posted on: 2005/6/2 10:27
1200 Coupe Rallycar
From Millgrove Vic OZ
As this has been a recurring problem I would have a good look at the crank thread condition. If all appears normal then dowel the crank and take the torsional load of the bolts. This is what kills the A series flywheels more than anything.
The bolts have a small PCD so this makes the problem worse. The last A12 hottie I just finished building had the crank triple dowelled so the dowel weights were evenly spaced for balancing.
By all means use 601 (shaft fit) Loctite and the primer T (3 Bond etc). Dowels are most important.
Posted on: 2005/6/4 13:42
Cheers Feral
