(1) 2 3 »
nissan 4cylinder engine with 8 spark plugs
Not too shy to talk
From Barbados
i found a nissan 4 cylinder engine with 8 spark plugs and it has a 5speed rwd box
on the tapic cover it has nissanZ
i want to know if the box can work on my l16
the owner told me it is either a 1800 or 2000 on the block has e2 so someone please clarify
Posted on: 2005/7/15 13:42
Re: nissan 4cylinder engine with 8 spark plugs
From Bridgetown, Barbados. W.I
Hey wat about the engine???
R they any good???Better than a L20b??
Posted on: 2005/7/15 13:45
Life's better SIDEWAYS!!
From Sydney, Australia
It's a Z18.
I'm pretty sure that the Z18 uses the same gearbox as all of the L-Series.
Posted on: 2005/7/15 14:05
From Fort Worth, Texas, USA
dattodude wrote:
It's a Z18.
Yes and no. The NAPS-Z engine leans the opposite direction form an L-series. The transmission will bolt to the L-series but the shifter will lean way over to the right. On a right hand drive car it might not be as big an issue as it is with correct hand drive.
Posted on: 2005/7/15 16:31
"There are 10 kinds of people in the world, those who understand binary, and those who don't.
From south australia
you could always but a bend in the gear shift to remady this
Posted on: 2005/7/15 16:40
Not too shy to talk
From Barbados
thanks alot
but what about the engine is it any good
what about the bore and stroke of the engine
Posted on: 2005/7/15 22:27
'Based heavily on the L18, the Z18T is a single cam, 8 valve fuel injected turbo charged motor. The two major differences between a Z-series motor and the L-Series motors, is that the Z-Series have a crossflow head and are an 8-plug design. The Z-series is essentially a replacement for the L-series that had been first used in 1968, the Z-Series motors were being used until the early 1990's.l
'Gearboxes are, like the FJ20, very similar to a L-Series 6 cyl gearbox, and they can be interchanged with an FJ20DE gearbox freely, being identical.'
Engine Model Power (Kw/Hp)
Z18ET 910 108Kw/145Hp @6000 RPM
Z18ET S110 108KW/145Hp @6000 RPM
Got that from a website with Z18 info on it
The bottom end of l series and Z is basically identical, just a x flow head....
The Z18ET pictured above
There ya go! Theres many people on this site who know ALOT about the Z series engine and are willing to help you with the performance/specs of these engines...
Dave
Posted on: 2005/7/16 4:34
From Perth Western Australia
to think that once upon a time i owned one of these and let it go to scrap metal
it even had a dogleg 5 speed, but i think it was a 2 litre, non turbo.
anyway, what cars did these engines come out in? I know it was some early skylnes, but i'm not sure which ones...
Posted on: 2005/7/16 5:22
Quite a regular
the 2 litre would ba a CA20
Posted on: 2005/7/16 5:57
In north america, we didn't get Z18, we got Z20 and Z22 also with 8 plugs. Might be what independentslider1 has found in Barbados.
Posted on: 2005/7/16 5:58
(1) 2 3 »
