a12 GX inlet/exhaust gasket
From Geelong, Vic
Just wanting to know where i can get one for a rebuild that im doing.
I assume that a normal a12 gasket set will be fine for the rest of the engine
Posted on: 2005/9/21 2:34
Re: a12 GX inlet/exhaust gasket
From Bunbury Western Australia
the rest of the engine will be the same as a standard A12 engine. The GX engine has oval intake ports and two studs at the top of each pair of intake runners, the bottom end is the same except the crank is balanced and runs 10.0:1 compresion ratio. I would suggest you try http://www.swmotorsport.com/enginegskt.htm
for all your parts as he seems rather cheap for prices
Posted on: 2005/9/21 7:09
From Melbourne, Australia
they are the same as a-14/15 manifold gasket, can get a gx one in bayswater (SE melb) if need be
Posted on: 2005/9/22 5:29
1200 Coupe Weekender
1200 Coupe Rallycar
1200 Coupe Wife's Daily
1200 Coupe Project A15ETT
From Christchurch NZ
I disagree. The GX head has taller intake ports. If you dont agree Ill post a pic.
Posted on: 2005/9/22 10:59
Forced Induction!
From Brisbane
Hey mate.
For my A14/A12gx head i got my Gasket from:
Stewart Wilkins Rallying
Ph: (02) 4577 2400
swrallying@ozemail.com.au
There a great quality gasket metal gasket composite with metal inlet surroundings
They cost $22 each back then (2years ago)
P.s Buy two you never know when you may need one in the future or incase of accidents ( I still have my spare one to date)
Posted on: 2005/9/22 11:46
OLD SkOOL POWeR!!! [color=CC0000]"with the sound & smell of twin 40s at full throttle!!!" [/
hey pigdog, give me a call tomorrow (friday) i've got a couple gaskets you can have if they fit.
cheers
Posted on: 2005/9/22 12:32
From Perth
I buy my big port ones from JTS
On my 3rd one this year..... don't ask
I usually get 2 at a time too..... helps to have a spare.
Posted on: 2005/9/22 12:59
