Ok its all theory but went to the wreckers today and couldnt help thinking of adapting two of these babies to an engine since they are so cheap and could work better than webers. First though one on the standard manifold would be a start.
Replacing the Weber 32/36 Carb with the CFI Throttle body from an EA Falcon.
Yes its from an EA cheap ass falcon but a CFI injection system is still better than a carb.
1, simplicity - original manifold can be used with weber adapter plate so it will fit under the bonnet looking original.
2, CFI EA Falcons everywhere.
3, Performance - The Falcon CFI is designed for a 3.9L six that produces 300+NM of torque.....CFM is not going to be a problem...however the chokes can be enlarged (40-43mm is possible)
4, Ease of instalation - The Ford CFI computer runs on a Lambda and is self tuning...It gets its firing signal from the coil....(as far as researched similar to camira delco unit)
5 - With a weber adaptor, the original air filter will still be able to be used...or a K&N for looks. (however will need modded bonnet bump)
Any ideas or thoughts anyone???
I saw bentaxelbobs photo somewhere here on the forums too on a gas conversion using this throttle body...
