Maddat
(Redirected from Mad Dat)
Category: Parts Suppliers
1200 performance parts. MAD DAT does mail order, shipping to other countries.
http://maddat.com.au sub-URL has changed once again!
22895.jpgAlbum 22895 22900.jpgAlbum 22900
1200 Parts
* GENUINE NISSAN PARTS (request)
Engine Swaps
* CA18/1200 Fitting Kit
* 13BT into 1200 Engine Fitting Kit
* SR20/1200 Fitting Kit
  see SR Crossmember
* Plug & Play Wiring Loom
* New Datsun 1200 Ute Engine X-Member
* Clutch Reservoir Relocation Kit
* Polyurethane Engine Mounts
* Underfloor Fuel Package
Suspension
* 1200 Conversion Sway Bar Kit
* Ultimate Race Coilover Package
* Lowered Front Strut Assembly Pair
* Adjustable Rebuilt Front End (suit Stanza/200B strut)
* Rebuilt Front End (suit 1200 strut)
* Tie Rod & Ball Joint Kit 1200
* 1200 Adjustable Lower Control Arms
* Caster Adjuster Bar Kit (1200)
* New Bush Kit Suit 1200 Models (blue polyeurethane)
* 1200 Genuine Nissan Rubbers
* 1200 Non-Genuine Nissan Rubbers
* Strut Brace (1200)
* Strut Brace Tri-bar (1200)
* Lowered Rear Springs
* Adjustable Rear Koni Shocks (pair)
* 1200 Steering Box Brace
Strut Brace Tri-bar
12844_4e4761c07f5cc.jpgPost 379706
Brakes
* Front Brake Conversion Kit (280mm rotors & 4-pot calipers)
* Front Brake Conversion Kit Alloy Hub
* Brake Booster/Master/Bracket/Clutch
* Heavy Duty Clutch Pedal
* CA18/1200 Brake Bracket
Diff
* Mad Dat Diff
** Diff Housing & Rear Disc Brakes (Shortened R31 28 spline)
** Diff - Gears & LSD
** Diff - Minispool
** Diff - KAAZ LSD
Turbo
* Intercooler & Radiator
* CA18/1200 Dump Pipe
* SR20/1200 Dump Pipe
Body & Interior
* 1200 Dash pad, RHD, brown only
* Short Throw Shifter (A-Series Gearbox)
* Replacement Shifter Bushes
* CA18/1200 Accelerator Cable
* SR20/1200 Accelerator Cable
* CA18 or SR20/1200 Speedo Cable
* Transmission Tunnel
* Universal Heater Box
* Steering Column Bush
* Hard Top Lid suit 1200 Ute
* Front Bumper
* Bonnet
* Tail Gate Outer
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Maddat"
This page has been accessed 20,997 times. This page was last modified 22:04, 17 November 2022. Content is available under Datsun 1200 Club.
