Square Light Grille
From Datsun 1200 Club
Category: Body
<-- back to Grille
Rectangular Head Lamps and corresponding grille were used in 1990s Sunny Truck and B140
The late Sunny Truck and Nissan 1400 bakkie grille uses standard large 2-headlamp 142mm x 200mm high/low) sealed beams.
16759.jpgAlbum 16759 31374.jpgAlbum 31374
31375.jpgAlbum 31375
JDM - From October 1989
62312-G1265 GRILLE KIT-FRONT 8910-
31376.jpgAlbum 31376 31377.jpgAlbum 31377 31377.jpgAlbum 31377 31379.jpgAlbum 31379
16659.jpgAlbum 16659 5201.jpgAlbum 5201
Parts
31370.jpgAlbum 31370
62312-G1265 8910- ORNAMENT-NISSAN
31363.jpgAlbum 31363
26380-U7400 CLIP-MOULDING [lower grille clips]
31372.jpgAlbum 31372
62318-01W00 8910- CLIP-MOULDING 4 [22mm long]
* 1980-1999 Nissan including 720/D21 and Sentra
31373.jpgAlbum 31373
South Africa
Bakkie B140
with "Nissan" oval badge
7403.jpgAlbum 7403 7404.jpgAlbum 7404
With "N I S S A N" letters
1123.jpgAlbum 1123
with NISSAN badge
22422.jpgAlbum 22422
Using on older 1200
Mounting points differ from all others, including Coupe/mid-ute grille.
Create brackets
18436.jpgAlbum 18436
Create headlight rim conversion plates.
squarelighttemplatesizeandshit.jpg 24656.jpgAlbum 24656
Use headlamps from any 2-light rectangular system car.
Use B310 head lamp rims (buckets)
19597.jpgAlbum 19597
19561.jpgAlbum 19561
16943.jpgAlbum 16943
Template:PartSearch SCREW-ADJUSTING 4 < 26022-31M00
* 1989-1994 Nissan B120
* 1983-1990 Nissan Pulsar NX
* 1980-1984 Nissan Datsun 810
but this might work 26022-78501
31380.jpgAlbum 31380
26025-N8500 720 screw grommet may work
31371.jpgAlbum 31371
Converting to Round Eye
See main article: Sedan_Grille#Fitting_to_Others
Custom Rectangular Headlight Grilles
sanitra FRP grille | Discussion: POST custom grilles
FRP peek-a-boo grille
20646.jpgAlbum 20646
See main article: Phantom grille
174_5b8042084aca6.jpgPost 489297 174_5b804284179a7.jpgPost 489297
Jetta(?) lights
7718.jpgAlbum 7718 7688.jpgAlbum 7688
Quad headlights
824.jpgAlbum 824 2239.jpgAlbum 2239 24646.jpgAlbum 24646
Late Sunny Truck retro-fit on Coupe
13301.jpgAlbum 13301 15589.jpgAlbum 15589
174_54eae4641a19e.jpgPost click for topic 20057.jpgAlbum 20057
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Square_Light_Grille"
This page has been accessed 22,368 times. This page was last modified 02:37, 29 November 2025. Content is available under Datsun 1200 Club.
