Water pump
Revision as of 12:23, 7 January 2012; view current revision
Category: Cooling System
Datsun 1200 used a traditional vane-type water pump, driven by the fan belt. The same pump was used from 1966 Datsun B10 to some 1982 Datsun B310. However, air conditioning-equipped models used a different hi-performance pump, and some models used a short-shaft pump.
Comparison
There are two basic water pumps for A-series engines:
  • Datsun 1200 is long shaft, large pulley (spins slower)
  • Newer is short shaft with spacer, small pully (spins faster)
  • Note that the pulley bolts are wider apart in the newer pump
  • Newer pump has studs for the spacer
  • Some aftermarkets pumps have a sheet-metal impeller, smaller but more agressive
  • Genuine Hitachi and Atsugi pumps (both A12 and A15) have a cast iron impeller
Heavy duty water pump installed on all 210s starting with late September 1979 productino of 1980 model year vehicles.
A14-433246-B
HLB310-693967
KHLB310-563501
WHLB310-047416
A15-028246
KPLB310-201907
WPLB310-021027
A12A-112069
LB310-0211047
LB310-044592
http://www.rockauto.com
Gasket (new and old style use same gasket)
  • 21014-H1001 GASKET-WATER PUMP through 1982 model year (A12, A13, A14, A15, A12A) $4.13
    • Replaced 21014-H1000, 21014-H1010
    • Replaced 21014-18000 GASKET-WATER PUMP B110 (but note B10 part number)
Pump for B110
  • 21010-18003 (BA010-M6626) ASSY-PUMP WATER B110 $45.67
  • 21010-18026 ASSY-PUMP WATER WITH GASKET (original PN)
  • 21010-18027 ASSY-PUMP WATER WITH GASKET 0870-0871
  • 21010-H1025 ASSY-PUMP WATER WITH GASKET 0971-1072 (1972 model year)
Others
  • 21010-H5025 (BA010-M6626) ASSY-PUMP WATER WITH GASKET 1172- $45.67 USD
    • Used through 1982 model years B110, B210, B310
    • 08110-85010 BOLT-HEX M8 FIXING WATER PUMP (2) from 1172
      • Superceds 08110-84810
    • 08915-13810 WASHER-LOCK FIXING WATER PUMP (5)
    • 08911-10810 NUT-HEX M8 FIXING WATER PUMP (3)
  • Bosch 96005 with 1.970" fan pulley bolt pattern.
B210, B310 OPTIONAL Aircon A14 From 0876
  • 21010-H7225 (BA010-H7289) ASSY-PUMP WATER WITH GASKET FOR AIR COND From 0876 Optional A14 $57.17
  • Bosch 96024 with 2.362" pulley bolt pattern
B110 RAW LIST
21010-H5025 ASSY-PUMP WATER WITH GASKET
BA010-M6626 ASSY-PUMP WATER WITH GASKET
21010-18003 ASSY-PUMP WATER
21022-18003 VANE-WATER PUMP
21026-73000 ASSY-SEAL WATER PUMP
21027-73000 ASSY-SEAT
21035-13202 BEARING-WATER PUMP
21054-18000 HUB-WATER PUMP
21014-18000 GASKET-WATER PUMP COVER
08110-84810 BOLT-HEX M8 FIXING WATER PUMP
21051-18000 PULLEY-FAN & WATER PUMP
21060-H1001 FAN-COOLING
21060-A4605 FAN-COOLING D=330 FOR TROPICAL USA
21060-N0100 FAN-COOLING,FOR TROPICAL USE
08120-62010 BOLT-HEX FIXING FAN
21069-21000 WASHER-COCK FIXING FAN
11720-G0300 BELT-FAN L=838
11720-18002 BELT-FAN L=838
  • Casting marks: Hitachi 13 long (smooth shaft) TO
  • Casting marks: Atsugi 13 short (ribbed shaft) X11 with studs
Datsun 1200 Pump vs Short Pump
  • pulley flange bolt centers: 1.970" vs 2.370"
  • pulley flange diameter: 2.42" vs 2.95"
  • pulley flange center locating hub: 0.85" vs 1.24"
  • Height of flange outer face from block: 2.38" vs 1.98"
Fan
Datsun 1000 used a metal 4-blade fan. Datsun 1200 uses a tough plastic 4-blade fan of 310 mm diameter (12.2 inch). They are strong and not known to break. Some newer A14 used the same diameter fan but with a negative offset and was used with a spacer. Most newer engines used a 330mm fan with spacer. Datsun 1200 used no spacer, but used a longer water pump. 330mm fan was Datsun 1200 OPTION FOR TROPICAL USE.
There are four Diameter of fans for RWD A-series engines:
  1. Lo-output engine: 310 mm diameter plastic (used on A10/A12/A13/A14/A15)
  2. High-output engine: 330 mm diameter plastic (also B110 OPTION)
  3. PB310 and HB310: 350 mm diameter - thermo, 7 blades
  4. Electric fan: 320 mm diameter, steel 5-blade (some 1980-1982 B310s)
In USA, A/C 1200s got a flexi-fan (fibreglas blades), while B210, B310 used #2 above.
USA dealer option flex-fan
Late Model Vanette A/C Type
Nissan items, From USA catalog:
  • 21060-H1001 FAN-COOLING(310 X 4) A12 [standard B110 fan] A12, A13. Also A14 GFU models, A12A, A14/A15 KFU
    • 08120-62010 BOLT-HEX FIXING FAN (4)
    • 21069-21000 WASHER-COCK FIXING FAN [bend-tab lock strip]
  • 21060-H9920 FAN-COOLING(310 X 4) A15 Manual from 0180
  • 21060-A4605 FAN-COOLING D=330 FOR TROPICAL USA (330 mm diameter) OP A12 CRANK B110
    • Supercedes 21060-N0100 OP A12 B110
  • 21060-H5700 FAN-COOLING(330 X 4) A13, A14, A15 (1974-1982)
  • 21060-W5000 FAN-COOLING(350 X 7) (FOR AIR-CON) B310 A14, A15
Spacers
  • B110 - no spacer
  • 21064-H5000 SPACER-FAN A13 [looks to be a thin spacer]
  • 21064-H7200 SPACER-FAN A14 to 0779 [thin spacer]
  • 21064-H9900 SPACER-FAN all From 0879 [thick spacer]
B210 used B110 pulley but with thin spacer.
A12A with A/C
  • 11720-H9911 BELT-FAN(977)(FOR AIR CON) OP A12 CAL from 0879
  • 11721-H7210,11721-H7200 BELT-FAN(970)(FOR AIR CON) FED
A14 With A/C
  • 21082-H7200 ASSY-COUPLING,FAN FOR AIR CONDITIONER A14 to 0776
    • 11721-69900 BELT-FAN FOR AIR CONDITIONER(960M M)
  • 21082-H7201 ASSY-COUPLING,FAN FOR AIR CONDITIONER A14 0876-up
    • 11721-H7200 BELT-FAN FOR AIR CONDITIONER(970M M)
  • 21082-H9920 COUPLING ASSY-FAN (FOR AIR-CON) A15 from 0180
  • 21082-H9100 COUPLING ASSY-FAN (FOR AIR-CON) OP A14,A15(CAL)
  • 21082-H9300 TEMP COUPLING ASSY-FAN (FOR AIR CON) OP A14,A15(FED)
Plastic Fan
310 mm Plastic fan
  • 3.82 diameter center section
  • 310 mm (12.2 inch) diameter blades
  • 1.28" thick
  • bolt pattern: 1.970"
  • hub locating hole: 1.24"
  • Bolts: (4) ten mm hex head, M8? threads. Early B110 used regular lock washers, later ones use metal strips and bent the up to lock the bolts.
310 mm fans came with these offsets:
  • Shallow used with short pump: flange from back: 10mm, from front: about 1+". Requires spacer.
  • Deepdish (B110) with long pump: flange from back: 0.84" (20mm), from front: 0.35" (9mm)
  • Unknown: flange from back: 5mm (reported)
Electric Fan
N10
You can fit the Datsun 310 (N10 Pulsar) fan into a 1200:
The thermo switch is in the lower radiator hose
  • 21596-M4960 N10 USA ADAPTER-THERMOMETER SWITCH A14S+A15S 0878-0781
  • 21596-M6460 N10 USA ADAPTER-THERMOMETER SWITCH E15S.MT 0881-
  • 21596-M6465 N10 USA ADAPTER-THERMOMETER SWITCH E15S.AT 1181-
Your choice of temps:
  • 21595-M0206 N10 USA SWITCH-THERMOMETER ON 85-90C
  • 21595-M4961 N10 USA SWITCH-THERMOMETER ON 72-75C
B310
The Datsun 210 (B310) "MPG" model featured an electric fan. MPG models had Manual transmission, chassis RSFU, RFN, from Sep 1980 with A14 engine w/o AC:
  • HLB310RSFU
    "R" 2-dr sedan, "S" Standard model, "F" Five-speed, "U" USA Federal (non-California)
  • HLB310RFN
    "R" 2-dr sedan, "F" Five-speed, "N" Canada
HL means: "H" A14 engine, "L" Left-hand-drive
Like other B310s it used a 13 psi radiator cap.
Part Numbers From 1980-1982 B310 USA, Canada manual
  • 21590-H9900 MOTOR ASSY-W/SHROUD
    • fan: 320mm diameter with 5 blades
  • 21595-M0206 SWITCH-THERMO
    ON: 83-87 C (181-189 F)
    OFF: 78-81 C (172-178 F)
  • 05412-1600P GASKET-B
  • 21596-M3000 ADAPT-THERMO SWITCH
    inline adapter, fits in radiator inlet hose
The stock Datsun Thermo switch has these specifications:
* ON: 83-87° C (181-189 F)
* OFF: 78-81° C (172-178 F)
Pulleys
These are the common pulleys:
- Datsun B110: 5.05" (~128mm) diameter, 2.33" high, locating hub 0.85"
- Datsun B310: 4.22" (~107mm) diameter, 1.74" high, uses spacer, locating hub 1.98"
The long pump (B110) uses a fan with positive offset. The short pump (B310) uses a fan with negative offset, but with a spacer. The overall height of fan from block face is the same for both models.
  • 21051-18000 PULLEY-FAN & WATER PUMP
    • Original Style: 1.970 inch bolt centers
    • A10, A12, A13, A14, A12A
    • B10, B110
    • B210 (with spacer)
    • B310 to 0779 (with spacer)
      • 11720-18002 BELT-FAN L=838 [For B110]
  • 21051-H9900 PULLEY-FAN & WATER PUMP
    • New style: 2.362 inch bolt centers.
    • Spacer has 1.970 holes on the fan end
    • B310 from 0879
    • A12A, A14, A15
      • 11720-H9910 BELT-FAN(987) A12A Cal From 0879 [For B310]
        • replaced 11720-77701 BELT-FAN(980)
The two combos of pump/fan/spacer interchange as a whole combo. The newer type allows the fan to be unbolted while the radiator is still in the car.
Presumably the A-series moved to a small diameter pulley to slow down pumping flow, perhaps to prevent cavitation at high speeds.
A third pulley is the B310 Aircon setup:
  • 21051-H7200 PULLEY-FAN & WATER PUMP (D=103)
    • B310
    • OPTION A14,A15
    • No spacer, but instead a clutch
    • 7-blade fan (350 mm)
      • 11721-H7210 BELT-FAN(970)(FOR AIR-CON)
Belts
V-belt
  • NISSAN: 11720-18002 BELT-FAN L=838 (838 mm length) B110
  • $5.99 Partsamerica.com Drive-Rite B70895
  • Gates 20777
  • V-belt, 29/64 inch by 33.5 inch length. About $6
  • V-belt (AC models) 45 inches ~$10
Delete
Water Pump delete cover plate
