Transmission Gear Control
Revision as of 23:54, 3 January 2013; view current revision
Category: Transmission
The 3-speed used a column shifter attached to the steering column. 4-speeds and 5-speeds use floor shift mechanism that is integral to the transmission itself.
Also see: Automatic Shifter
Shift Knobs
クシフト ノブ
8mm x 1.25 threads
The stock Datsun 1200 4-speed knob is black.
3-speed column-mounted shifter:
3623.jpg KB10 Sports option 6580.jpg Sunny 1000
2209.jpg options 3157.jpg Stock GX-5
11443.jpg PB110 2871.jpg Custom Knob
9082.jpg B-210 8267.jpg B310
10121.jpg aftermarket? 10712.jpg Classic 8-ball
If you want just the pattern on top, you can buy those from Autobarn and other similar stores as a badge with sticky back.
16869.jpg 16999.jpg 22094.jpg 22124.jpg 22294.jpg 22462.jpg 22463.jpg 22464.jpg 22465.jpg 22466.jpg 22467.jpg 22468.jpg 22469.jpg 21827.jpg
Shifter Bushes
The bushings become dry rotted,broken. New ones restore your shifter for tight, precise shifting again.
I got tired of the shifter in my 1200 flopping around, so I changed the bushings. It took about 5 minutes. I don't know what happened to the old bushings, I didn't see any in there at all. It was nice and tight last year, but one day it just started flopping. I reckon the old ones shattered into a million pieces. Anyways, for 5 minutes and 5 dollars, it sure works better now.
Top: two plastic bushes, stock type.
Bottom: Racing aluminum bushings for better control, but transmit vibration.
"Head" bush at the end, regular bushes on the side of the hole
Short-throw Shifter
A short-throw shifter is longer below the fulcrum, so you only need the move the shifter a little to move the gears a lot.
Of course if the fulcrum is higher up on the shifter, you need to move the fulcrum mount point on the transmission up higher to match.
Discussion: How to make a short shifter
Simple Method
Lengthen the shifter bottom section: cut just below the fulcrum pin in the round part. Then just weld in a piece of 3-4mm steam pipe 1 - 1.5 inches long then weld the fulcrum back on top. On the stick cut the bottom off and exten it the same amount and then weld the ball back on.
Or instead of modifying the 56/60-series shifter, use an L-series shifter (which has a higher fulcrum).
To modify the transmission, bolt extension plate on the shifter brackets:
Pro Bracket
Angelo made the adapter and stick to move the fulcrum point up about 1.25"/32mm. The stock shifter moved about 6-7" from 1st to 2nd, now it moves only 3". Side to side movement is still the same as before. It has taken me a few days to get used to. The throw is so short, it's difficult to go from second to third and from fourth to fifth. Tap the original holes for the fulcrum pin with an M10x1.5 and used short flathead/countersunk M10 screws to mount it.
Another version:
63/71 Shifter
63-series and 71 series already have a higher fulcrum point. Some later 71-series are adjustable for low- or high- fulcrum.
1984 adjustable shifter re-bent similar to 1200 shifter:
Comparo
Pictures thanks to DatzenMike.
Adjustable, just reverse the plastic insert to fit different transmissions:
There is a difference in pin heights on the FS5W71B transmissions.
4-speed & 5-speed up to 1980
4-speed & 5-speed AFTER 1980
Some FS5W71B shifters from 720/S110 in multiple lengths
The two plastic bushings and the spring inside can be swapped upside down to move the pin hole higher up to move the fulcrum point up.
Shifter Bushings
  • Nissan 32855-H1010 - manual transmission. The original part number was 32855-24900. (2 required).
These bushings fit:
  • 1967-1970 B10
  • 1971-1973 B110
  • 1974-1978 B210
  • 1969-1973 510
  • 1977-1980 810
  • 1973-1979 620
  • 1980-1985 720
  • 1977-1983 200SX
  • 1969-1973 Patrol
Shifter End Bush
  • Nissan 32861-24900 BUSH-CONTROL LEVER HEAD
Shift Knobs
4-speed Shift Knob
  • Nissan 32865-H1000 replaced 32865-27700
Boots
Large Boot
Also see: Console
Interior (large boot)
  • Nissan 74963-20900 BOOT-CONTROL LEVER
Small Boot
At transmission (small boot)
  • 32862-G1200 BOOT RUBBER C/L
    • replaces:
    • To 0373: Nissan 32862-24900 BOOT-RUBBER CONTROL LEVER
    • From 0473: Nissan 32865-H1000 BOOT-LEVER CONTROL LEVER
These all interchange. Bends/length differ.
  • 56-series shifter
  • 60-series shifter (both 4 & 5-speeds)
The 63-series 5-speed shifter fits deeper into the transmission, so does not interchange. CONVERSELY, the 60-series shifter does not work well with the 63-series 5-speed, as the length of the shifter from the crossbolt to the plastic pivot point at the end of the shifter is about 10mm shorter. But 60-into-63 might work in a pinch.
The B310 floor boot is different:
32862-H7300 BOOT-RUBBER CONTROL 4-speed,5-speed, 56,60-series $4.87 USD
75950-H8510 BOOT-CONTROL LEVER [Floor hole] COUPE OP.SEDAN $28.55 USD
75951-H9100 HOLDER-BOOT SEDAN.DX $6.30 USD
* 75950-H9100 BOOT-CONTROL LEVER SEDAN.DX (BROWN) $63.52 USD
* 75950-H9101 BOOT-CONTROL LEVER SEDAN.DX (BLUE) -0779 $57.12 USD
* 75950-H9103 BOOT-CONTROL LEVER SEDAN.DX (BLUE) 0879- $63.52 USD
* 75950-H9102 BOOT-CONTROL LEVER SEDAN.DX (BLACK) $63.83 USD
