Competition Oil Pump
Revision as of 08:29, 16 April 2014; view current revision
Category: Engine Lubrication System
Nissan Competition Oil pump can in two varieties: 1)high pressure and 2) external line version.
Also see Oil Pump Coolers
High Volume Pump
Ssee Hybrid High Volume Pump
From 1984 Nissan Competition Catalog
LUBRICATION (A-SERIES)
High Pressure Pump
  • 15010-25720 COMPETITION OIL PUMP Generates an oil pressure of over 100psi and does not self prime
  • 15010-M0821 COMPETITION OIL PUMP (FWD) Similar to 15010-25720 except unit is designed for FWD Datsuns with A-series engines
  • 11710-H5720 ALTERNATOR BRACKET For use on B210 and 210 models when installing 15010-25720 oil pump
  • 15025-25720 GASKET FOR COMPETITION OIL PUMP T= 0.10mm (Yellow)
  • 15025-25721 GASKET FOR COMPETITION OIL PUMP T=0.12mm (Blue)
  • 15025-25722 GASKET FOR COMPETITION OIL PUMP T = 0. 1 4mm (Green)
Dry Sump Pump
  • 15010-M0821 DRY SUMP OIL PUMP Similar to 115010-25720 except has additional fittings for dry sump system
  • 15025-H5720 GASKET FOR DRY SUMP OIL PUMP T = 0. 10mm (Yellow)
  • 15025-H5721 GASKET FOR DRY SUMP OIL PUMP T = 0. 1 2mm (Blue)
  • 15025-H5722 GASKET FOR DRY SUMP OIL PUMP T = 0. 14mm (Green)
