B10 Lights
Revision as of 07:50, 22 September 2015; view current revision
Category: Datsun B10
Datsun 1000 tail lights vary by model and country.
Side Lights
Datsun 1000 front guard was fitted with different indicator lamp lenses depending on the year and trim.
  1. 1967 Model: Small Round dome type
    • 26161-18000 LENS-lamp
    • pic
    • Looks similar to 510 rear USA (EVER WING A3036 SAE P167), but this is much flatter.
    The B10 lens sticks out quite a bit.
  2. 1968, 1969: Short spear
    • about 10cm long
    • 26161-25700 LENS-lamp (from C/# B10-80026, VB10-84001)
  3. 1970: Long spear (13cm+). Same as Datsun 510 "1600"
    • Replaces spear A
    • 26161-A4600 LENS-lamp (from C/# B10-350001, VB10-240001, KB10-80001, B20-61001)
      • JDM & ADM 510s
        pic
      • These look similar but are asymmetric:
        • 26161-21000 ASSY LENS WITH RIM RH 1068- USA
        • 26166-21000 ASSY LENS WITH RIM LH -0969 USA
Datsun 521 pickup in USA uses a spear that looks similar.
Datsun 521 part number 26160-B0101 is identical to the 1000 1968/1969 short spear lamp.
Coupes uses same lense as others, but the assembly (lamp housing) is different for Coupe.
Position
Late Ute
Front Lights
Datsun 1000 was fitted with clear lens front combination lamp.
Australia
Aussie models had a orange bulb offset to the inside of the lens???
  • clear rectangular lense A
  • clear rectangular lense B
  • Coupe: Large Amber lens
  • 2-section (amber + clear)
Front%20Indicator%20Assembly%20-%20Left%20(%27Everwing%27%20EW6030L).jpg Left Light Assembly.
Front%20Indicator%20Amber%20Lens%20-%20Right%20(26122-20900).jpg 26122-20900, Right Amber Lens.
Front%20Indicator%20Rubber%20-%20Right%20(26123-27750).jpg 26123-27750, Right Gasket.
Japan-market. Clear lens with orange-bulb centered.
  • 26121-18000 LENS-parking & turn signal (R.H.) ALL except Coupe [Clear lens, Single bulb]
  • 26121-27700 LENS-parking & turn signal (R.H.) ALL except Coupe [Clear lens, Single bulb]
  • 26121-25702 LENS-parking & turn signal (R.H.) Coupe [Clear lens, Single bulb]
Position
  • Sedan, Van, Ute: Fitted below the headlight, above the bumper
  • Coupe: Fitted below the bumper
Tail Lights
Datsun 1000 rear lamps were combination type.
Sedan
B10 Sedan rear lamps came in two styles.
180 type: 1967-1969
 full
H01 type: 1970 (from October 1969)
 full
180 Amber inside
180 Red inside
H01 Indicator outside
H01 type
6429.jpg th_B10a.jpg th_B10b.jpg th_H01a.jpg th_H01b.jpg th_H01c.jpg th_b10tla.jpg th_b10tlb.jpg th_b10tlc.jpg
Coupe
KB10 taillights
Wagon
VB10 lamp
1967-1968 (to September 1969)
1969-1970 (from October 1968)
Pickup
B20 Pickup
