Engine Bay
Revision as of 04:20, 8 December 2015; view current revision
Category: Engine Bay
The Datsun 1200 has a small Engine Compartment as is fitting for its optimized lightweight design. Yet still there is plenty of room for maintenance. Nissan calls it the engine room and many people call it the engine bay.
Measurements
Approximate measurements follow. They are hand measured, so the accuracy is fair, but the precision is questionable.
  • 36.5": Width between Strut shafts at top
  • 30.75": Width between strut tower faces at A12 rocker cover height
  • 26.25": Length from firewall to radiator mounting surface
    Firewall measured behind engine, above the tunnel
  • 27.12": Length from core support header to firewall
    firewall measured at raised boss
  • Width between subframe rail faces:
RHD
Comparision
B10 (Datsun 1000) more photos
B110 (Datsun 1200) more photos
B210 (Datsun 120Y/140Y/B-210)
B310 (Datsun Sunny/210/120Y/130Y/140Y/150Y)
6477.jpg B10 (quick ID: No strut towers)
1759.jpg B110 (quick ID: bonnet seal is above the wiper motor)
17200.jpg B210 (quick ID: bonnet seal is below the wiper motor)
7330.jpg B310 (quick ID: bonnet seal is low and nearly flat)
Bay Lower Cover
For aerodynamics. See Dust Pan
