Console
Revision as of 07:40, 20 September 2016; view current revision
Categories: Interior | Fibreglass
Datsun 1200s were fitted with various consoles including full-style and compact style.
Full Size
Full size console was usually fitted with a Clock. The Tachometer was rightly fitted into the dashboard, but you can put the tachometer in the console if you so choose.
full
full
5703.jpg 21473.jpg :full
Heater vents still work even with the console in place
21478.jpg Brackets
592.jpg w/o heater
6595.jpg SSS
1970-1971 appears to be gold tinted, while 1972 seems to be silver-tinted. But the GL brochure shows what looks like a black tinted console. The catalogs show only two numbers: early and 1972.
th_gsi.jpg GL 460.jpg GX Facelift
25955.jpg th_lc1.jpg th_lc2.jpg th_lc3.jpg th_lc4.jpg th_lc5.jpg th_lc6.jpg th_lc7.jpg th_lc8.jpg th_lc9.jpg th_lca.jpg th_lcb.jpg th_lcc.jpg
Bracket tabs are hot air deflectors
full
Consoles assemblies come with Clock mask, Clock is sold separately.
Sunny 1200 Optional Parts catalog
* 74980-H2010 ASS'Y-CONSOLE BOX (大型 large type) GL/GX manual
* 74980-H2020 ASS'Y-CONSOLE BOX (大型 large type) GL automatic
Japan catalog
1972 Japan [Facelift] catalog
* 74980-H3320 CONSOLE BOX ASS'Y-with bracket GL/GX 4-speed
* 74980-H3330 CONSOLE BOX ASS'Y-with bracket GL automatic
USA Catalog
* 74980-H1801 ASSY-BOX CONSOLE MANUAL -0772
* 74980-H2010 ASSY-BOX CONSOLE COUPE MANUAL 0772-
* 74980-H7000, 74980-H7001 ASSY-BOX CONSOLE MANUAL 0772-
Mask
Console mask starts with the same plastic piece as the dash mask, and then rivits it to a complex aluminum adapter.
'Sunny'
74990-H2021 MASK-clock [console]
'Datsun'
74990-H1800 MASK-CLOCK [console]
Compare to simpler Dash blank
The console mask has an aluminum adapter bracket to allow it to bolt to the three console holes.
Clock Fitting
Just unbolt the mask plate, and bolt in the Clock. The same clock fitted in the dash is used in the console.
The second set of tabs - back from the face - are used to bolt into the console
click
If the side-brackets are missing - e.g. a 1976-up Truck clock - you may fabricate a simple bracket to hold the clock in place.
discussion
27389-H2300 SPACER-rubber (fixing clock to console box)
25962.jpg  post
If you buy a second-hand clock and end up with the Facelift clock, cut the long bracket off to make it fit in the console:
click
24043-H2000 ASS'Y-CABLE, for console clock GX [extension harness for clock wiring]
Fibreglas
Glassfibre versions
Short Console
full
The short pocket-type console was fitted to:
* Automatic DX
* OPTION 4-speed 1200s STD and DX
* JAPAN 3-speed column shift OPTION
* B120 Pickups as standard equipment (except STD models)
full
Brackets (B122 pictured)
74987-H1801 BRACKET-CONSOLE FRONT [long bracket]
74988-G1161 BRACKET-CONSOLE [rear, short bracket]
01241-00061 NUT (4)
08510-61697 SCREW (holding console to bracket)
08510-61642 SCREW (holding bracket to floor)
Automatic
20399.jpgAlbum 20399
Floor Trim Part Numbers
* G4980-H1025 ASS'Y-CONSOLE BOX [short, OPTION for 3-speed (column shift)]
Japan CONSOLE BOX
* 74980-H1801 ASS'Y-CONSOLE BOX, 小型 (small type) with bracket 4-speed (ex. GL, GX)
* 74980-H1021 ASS'Y-CONSOLE BOX, 小型 (small type) with bracket A-all (ex. GL)
North America
* 74980-H1921 ASSY-BOX CONSOL SEDAN,COUPE AUTOMATIC
* 74980-H1801 ASSY-BOX CONSOL SEDAN,COUPE MANUAL OPTION
* 74980-H7000 ASSY-BOX CONSOL SEDAN,COUPE MANUAL OPTION 0772- [Fire-resistant?]
B120
* 74980-H1801 CONSOLE BOX KIT-FLOOR W/BRACKET     -7803 [Black]
* 74980-G1160 CONSOLE BOX KIT-FLOOR W/BRACKET 7804-7907 DARK BROWN
* 74980-G1660 CONSOLE BOX KIT-FLOOR W/BRACKET 7908-8109 BROWN
* 74980-G1900 CONSOLE BOX KIT-FLOOR W/BRACKET 8110-8910 [revised finisher panel]
* 96910-95W00 CONSOLE BOX KIT-FLOOR W/BRACKET 8910- GRAY
Shifter Boot
シフト ブーツ Boot for shift lever. Full and short consoles use the same boot.
Aftermarket
Nissan
Buy from Bprojects
BOOT
74986-H1801 ASSY-BOOT MANUAL [Black] -7803
74986-H7000 ASSY-BOOT MANUAL 0772- USA [Black Fireproof?]
74896-G1160 7804-7907 [Dark Brown]
74896-G1660 7908-8910 [Brown]
96935-95W00 8910- [Gray]
Finisher
08961-13240 NUT (4) (holding finisher to console)
74982-H1021 FINISHER-CONSOL BOX AUTOMATIC
74982-H1801 FINISHER-CONSOL BOX MANUAL -8109
74982-G1900 PANEL-CONSOLE A 8110-8910
96930-95W00 PANEL-CONSOLE A 8910-
Fibreglas
Glassfibre versions
Aftermarket
Amco aftermarket/dealer installed
post
Custom
Portugal 1200s. Are the custom consoles?
Documentation
1555.jpg JDM 2209.jpg USA
Alternative Sources
Honda Civic
Barina
Barina
PB110
Sunny Excellent used consoles the similar to B110, but extend up further with vents that drop down in the top. Also extends further back under the handbrake lever.
  • Console could be had without any gauges (just a Sunny plate)
  • Clock with cubbyhole below was optional
  • Clock with two small gauges was optional
  • Has heater vent extender with directional (!) vents
* With option Large Clock
* With option auxliary gauges
  * Oil P (oil pressure) measured from 0-6 kg/cm3
  * AMP (ammeter) from -30 to +30
A. DX 'Sunny' plate
B. GL/GX Clock with cubbyhole
C. OPTION Clock with oil & AMP gauges
Gold-tint or Silver-tint
DX MASK - 'Sunny' clock blank
GL/GX MASK - Clock with cubbyhole
OPTION MASK - Clock with Gauges
BOX ASS'Y-console
74980-H2501 (black) DX
74980-H2601 (black) GL
74980-H2602 (blue)  GL
74980-H2701 (black) GX
74980-H2702 (brown) GX
* Also available in DX AUTO and GL AUTO versions
* Colors are on the Finisher and the vent Louvers
MASK-console box body
コンソール ボックス ボヂー マスク
74982-H2501 DX    'Sunny'
74982-H2600 GL,GX [clock]
74982-H2601 OP.   [gauges]
74990-H2600 MASK ASS'Y-clock
27380-H2600 CLOCK ASS'Y [same as PB110 dash clock]
B210 Console
Does not fit the 1200 well
H50 short type
H51 short type (late A12)
H59 long type black or brown
* with coin tray
* with pocket
* with clock B210
* with twin gauges B210 or PB210
B210 console
74598-H5000
full
full
full
full
full
full
B310 Console
Sold by Bprojects
96935-H8500 BOOT (BLACK)(G) <> 96935-H8560 $35.58 USD
96935-H9160 BOOT (BLUE) 0879- $32.62 USD
96935-H9100 BOOT (BLUE) -0779 $30.12 USD
96935-H8561 BOOT (BROWN) $35.58 USD
838.jpg 1350.jpg 834.jpg 3069.jpg 4748.jpg 4823.jpg 4939.jpg 5619.jpg 9471.jpg 19640.jpg 21466.jpg 21467.jpg 21471.jpg 21472.jpg
click
click
keywords: コンソール
