Compressor brackets
Revision as of 00:20, 14 July 2018; view current revision
Category: Heating And Ventilation Systems
Various types of brackets were used over the years to fix the aircon compressor to the engine. Early A12 and late A12 brackets differ. You can make your own brackets, buy used from a 1200 or 210/B310 or A-engined Cherry/Pulsar/Vanette, or buy new.
The engine parts needed for aircon are 1) Compressor 2) Compressor bracket 3) Crankshaft Pulley and 4) V-belt
B110 1970-1976 All custom, various types
B120 1978-1979 Factory high-idler mount
B120 1980-     Factory low-idler pulley mount
A bracket can be fabricated of two 8mm strips of metal (going across) and two vertical strips to connect to the compressor. An idler pulley can be added from a Nissan or other vehicle.
High-mount idler | Low-mount idler
20088.jpgAlbum 20088 20089.jpgAlbum 20089
Early Engine
Compressor on early A12 (1970-1973, front-mount distributor type)
Custom install on right-side, battery moved to trunk, compressor place just above oil pump. Mounted like an alternator with no idler pulley
This in an Australia 1200. It uses a humongous bracket to space the compressor out past the low-mounted alternator.
9377.jpgAlbum 9377 9378.jpgAlbum 9378
15371.jpgAlbum 15371
Here is a USA 1200 with a slightly different setup:
2185.jpgAlbum 2185 16244.jpgAlbum 16244
Uncommon Right-side compressor mount
14950.jpgAlbum 14950 14953.jpgAlbum 14953
Late Engine
For late model A12 (1974-up, mid-distributor type).
unknown bracket
13822_55619c6b37967.jpgPost 468324 13822_543ba7b1b39af.jpgPost 460546
Custom bracket for modern short compressor, made out of 6mm stock
close-ear H86 from B310 (1981-1982)
174_5806b82922ab6.jpgPost 481951 17554_5806e018e2f44.jpgPost 481953
wide-ear H74 from B310
24729.jpgAlbum 24729 18710.jpgAlbum 18710
1978 Factory Bracket
Old compressor type (York-type)
21822.jpgAlbum 21822 23103.jpgAlbum 23103
1979
Starting august 1979 -- New Compressor-type
See Main Article: 1979 aircon
21821.jpgAlbum 21821 20084.jpgAlbum 20084 15194.jpgAlbum 15194
Low-mount Pulley (1979-up) for radial type compressor
20081.jpgAlbum 20081 26588.jpgAlbum 26588 21783.jpgAlbum 21783 20079.jpgAlbum 20079 cb0.png cb1.jpg cb2.jpg cb3.jpg
Unicla
1977 Unicla compressor mount
25585.jpgAlbum 25585 25586.jpgAlbum 25586
idler pulley
Early B210 Japan
25501.jpgAlbum 25501
'5 SPEED DATSUN 120YCCC'
17554_5806e01fac29e.jpgPost 481953
Vanette
C120 Vanette A15 mounts below oil pan rail
JDM B120
FOR YORK-TYPE COMPRESSOR (1978)
* 11910-G1661 BRACKET A
* 11911-G1661 BRACKET B
* 11925-A0100 IDLER PULLEY
* 11933-A0100 ADJUSTER NUT
* 11917-M0100 ADJUSTER BOLT
JDM B120
FOR RADIAL COMPRESSOR (1979-_)
* 11910-G1615 BRACKET 7908-8910
* 11910-95W00 BRACKET 8910-
* 11925-G1615 IDLER PULLEY
USA B310
11910-H9100 BRACKET-COMPRESSOR -0678
11910-H9101 BRACKET-COMPRESSOR 0778-
11910-H9900 BRACKET-COMPRESSOR 0879-
JDM B310
11910-H7401 -8010 BRACKET-COMPRESSOR
11910-H8661 8011- BRACKET-COMPRESSOR
11925-H8900 IDLER PULLEY
JDM A10 A14
11910-H7401 BRACKET-COMPRESSOR -8003
11910-G2500 BRACKET-COMPRESSOR 8004-
11925-H8900 IDLER PULLEY 7804-
11925-M3001 IDLER PULLEY -7803
11925-W0400 IDLER PULLEY 7906- A14,Z16/Z18
11926-W0400 BRACKET-IDLER PULLEY 7906-
JDM C120
11910-G2500 BRACKET-COMPRESSOR 8106-8210
11910-G3400 BRACKET-COMPRESSOR A 8210-
11911-G3400 BRACKET-COMPRESSOR B 8210-
11910-G3401 BRACKET-COMPRESSOR 8407-
JDM C22 - high-mount pulley bracket
11910-G5100 BRACKET-COMPRESSOR
11910-G5110 BRACKET-COMPRESSOR
