Badges
Revision as of 08:33, 6 June 2018; view current revision
Category: Body
Datsun 1200s came with several badges (emblems). The original 1200 badges were metal, but the new ones -- genuine Nissan items -- are a high-quality plastic that looks very good. Aftermarket reproduction badges vary in quality from poor to very good.
Also see: Badge Part Numbers
Genuine Nissan badges are metal or plastic depending on the year made.
Various early B110 Sunny Emblems (Japan)
2200.jpgAlbum 2200
1972 JDM Facelift emblems
11467.jpgAlbum 11467
Badge Installation
Most Datsun badges are fastened via Hole-barrel nuts.
1. Two or three simple holes are drilled in the sheet metal
2. Round inserts are pushed into the sheet metal
3. The badge is pushed into the inserts
The inserts may be stuck to the old badge, you can see them on this GL badge:
25777.jpgAlbum 25777
The nuts are not sold separately, but can be found on wrecker cars or old broken badges.
Emblem/Trim Retainers (Hole Stud Tubular Nut/Panel Tubular Speed Nut)
174_5705c1e0407b8.jpgUpload click to view
? Tubular Speed Nut 1/8" Stud. #018 Fits 5/32" to .161" Hole. 0.012-0.018" Panel Thickness ?
Market Differences
* Japan market 1200s used "Sunny" & "S" badges
* Export market 1200 used "Datsun", "D" badges
917.jpgAlbum click to view 6001.jpgAlbum click to view
20894.jpgAlbum click to view 20867.jpgAlbum click to view
Colors
Most badges, especially the script ones, are simple silver color.
Sedan "S" and "D" grille emblems have red and blue bars:
11318.jpgAlbum 11318
Coupe "S" and "D" round emblems have tricolor red, white and blue pie sections:
16678.jpgAlbum click to view 16758.jpgAlbum click to view
Some are faded after all this time:
19630.jpgAlbum click to view
Most are faded to no color after 40 years:
5199.jpgAlbum click to view
Coupe
See main article: Coupe Badges
Sedan
See Main Article: Sedan badges
Sunny Truck & Ute
See main article: Truck Badges
Van
Van uses the same badges as Sedan:
* Grille 'S' ornament (including facelift version)
* No grille trim badges (Deluxe, GL or GX)
* 'Sunny' rear quarter badge
* 'Sunny 1200' rear badge
* 'Deluxe' rear badge (DX only, early version)
* 'Sports' rear badge (DX 4-speed only)
In addition, Van used these unique badges:
96905-18100 LABEL-loading capacity '400 kg'
* lower left side
96907-G1100 LABEL-4 speed Van-Std T, Van-P T
* middle height right side
'VAN' badge - Portugal
421.jpgAlbum click to view 25849.jpgAlbum click to view 25850.jpgAlbum click to view
Van Deluxe (Japan)
25026.jpgAlbum 25026
Van Deluxe (export)
753.jpgAlbum 753
Van - Portugal
Custom
'DATSUN 1200' coupe badge + Portuguese 'VAN' badge
918.jpgAlbum click to view
GX
GX trim used mostly standard badges, but some are specific and are shown here.
1200 grille early & grille late
62330-H2325.jpg 25658.jpgAlbum click to view
1200 Sedan badges pillar
18264.jpgAlbum click to view
1200 Coupe Badges side
GX5 grille & boot
62330-H7225-1.jpg 25659.jpgAlbum click to view
Custom? GX-sports badge, reportedly made of aluminum
26904.jpgAlbum 26904 26905.jpgAlbum 26905
Non-1200?
9804.jpgAlbum 9804
1200 SSS
The Datsun 1200 SSS sedan was a product from Datsun New Zealand.
SSS badge on the glove box. Anyone have a photo?
SSS left-side grille emblem
62800-N0401 MARK-radiator grille "SSS"
* Datsun 510 Coupe KPK, Sedan PTK
* Datsun 1200 SSS
5460.jpgAlbum 54605438.jpgAlbum 5438
82858-U0800 boot/rear badge- same as 610/180B SSS
Non-1200 SSS
1200 SSS badges are not to be confused with similar badges from other Datsuns that are pointy on the bottom.
Pointy badge not Datsun 1200 SSS
5384.jpgAlbum 5384
Black SSS badge is not 1200?
5567.jpgAlbum 5567
Steering wheel badge??? South Africa
16577.jpgAlbum 16577 16576.jpgAlbum 16576 16722.jpgAlbum 16722
910 Bluebird SSS
62892-W3500 Front Grille Mark 8201-8907 [triangular 'SSS']
62896-W1200 Front Mark 7910-8112 [octagonal 'SSS']
810 Bluebird SSS [Sedan:62396-U7625, Coupe:62396-U8325]
62397-U7600 'SSS' ~120 mm long
411 SSS rear badge
11023.jpgAlbum 11023 9998_55429568a2c2c.jpgPost click for topic
PB110 Sunny Excellent
See Main Article: PB110 Badges
Datsun 1200 S1
The Datsun 1200 S1 2-door sedan was a Datsun of Portugal offering.
* S1 grille badge
* S1 boot badge, fitted to left of the right taillight
See main article: Datsun 1200 S1
Custom
Grille-fixed Sedan boot badge 'Datsun1200' with the 1200 painted red
5732.jpgAlbum 5732
Nissan hamburger grille badge
19414.jpgAlbum 19414
Germany
'DATSUN' rear side
'DATSUN 1200' boot right side
26374.jpgAlbum 26374
Interior
The only interior badge is the steering wheel, a small piece of aluminum trim. See the steering wheel article.
Part Sources
* Nissan USA and Nissan Japan are out of badges
* Nissan Australia apparently still has some.
* eBay has them from time to time
* Yahoo Auctions Japan always has some
* Too Intense usually has some 1200 badges
* Aoba Auto
* South Yokohama
* Matsuoka
Be careful of the quality:
11377.jpgAlbum click to view 13484.jpgAlbum click to view
Malaysia repro vs Nissan item: This reproduction badge has has poor chroming and what appears to be hand-painted coloring that doesn't exactly stay within the lines. However, other reproduction badges may be high quality.
8238.jpgAlbum click to view 8239.jpgAlbum click to view 8240.jpgAlbum click to view 8389.jpgAlbum click to view
th_8390.jpgAlbum click to view
エンブレム バッジ マーク
