Relay
Revision as of 21:08, 23 February 2022; view current revision
Categories: Body Electrical System | Engine Electrical System
Nissan relays
Also see:
* Horn relay
* Choke relay
* Fuel pump relay
* EFI relay
* Headlight relay (stock 1200 does not use one)
3-pin
25630-79960
26320-D0100
15A T-connector
25630-79960
25630-C9960
25630-C9961
25630-C9962
4-pin
25230-0B000
25230-0B060
25230-0B080
25230-61A05
25230-61A10
25230-C9965
25230-C9970
25230-C9980
25230-C9985
15A
25230-C9980 15A
25230-C9965 15A
20A
25230-59975
20A
25230-C9970
25230-0B000
30A cross-shape connector
25230-C9970
25230-C9980
25230-C9965
NO A-shape
25230-61A05
25230-61A10
25230-C9970
25230-C9980
25230-C9985
25230-0B000
NO open spade
82501-44060
25230-89977
25230-89975
25230-C9977
25230-C9965
25230-79971
25130-79915
25230-5T020
25230-18A00
5-pin
NO/NC with Common pin - open spade
25230-W1300
25230-C9900
25230-C9905
25230-C9907
25230-C9963
C9905
25230-C9971 15A
6-pin
25230-79963
25230-C9925
25230-C9963
25550-25004
C99
NO/NC open spade
25230-C9910
25230-C9915 15A
NO/NC h-shape connector
25230-0B010
25230-81W00
25230-C9962 15A
25230-C9972
25230-C9973
NOx2 open spade
25230-C9920
25230-C9925
25230-C9927
C9920
Misc
15A
25230-79978
20A
25230-79962
24V
25230-0B060
24V 25A
25230-04G00
25230-89915
6-pin spade connectors, Normally Connected + Normally Open
B5230-89985 supercedes 25230-89915 RELAY ASSY-AUTO CHOKE $24.57 USD
* B310 Choke Wiring
* 510 Headlight Relay
* Passing Lamp
B5230-89985
  • B5230-89985 Supercedes: 25230-89915; 25230-89918; 25230-89964; 25230-H6202; 25230-N4300; 25230-N5310; 25230-R0100; 25230-U2000; B5230-89918; B5230-N4300; B5230-N4400; B5230-N5310; B523089985; B7000-N8501KT
  • Used from 1972-1984
  • Used by 280Z, 280ZX, 1972-1973 510, 1975-1976 610, 1975-1979 710, 1978-1981 810, 1984 910 Maxima GL
<B5230-89985> square relay with 6-pin mini-harness
28500.jpgAlbum 28500
Original part <25230-89905> JIDECO RELAY type K5 with integral 6-pin connector
<25230-89915>
23482.jpgAlbum 23482
  • S30 ignition/fuel pump RELAY B
