Nissan relays
Also see: * Horn relay * Choke relay * Fuel pump relay * EFI relay * Headlight relay (stock 1200 does not use one)
3-pin
25630-79960
26320-D0100 - | |
15A T-connector 25630-79960 - | |
25630-C9960 25630-C9961 25630-C9962 - | |
4-pin
25230-0B000
25230-0B060
25230-0B080
25230-61A05
25230-61A10
25230-C9965
25230-C9970
25230-C9980
25230-C9985
15A 25230-C9980 15A 25230-C9965 15A
20A 25230-59975 |- | |
20A 25230-C9970 25230-0B000
30A cross-shape connector 25230-C9970 25230-C9980 25230-C9965
NO A-shape 25230-61A05 25230-61A10 25230-C9970 25230-C9980 25230-C9985 25230-0B000 || | |
NO open spade 82501-44060 25230-89977 25230-89975 - - | -
25230-C9977 25230-C9965
25230-79971
25130-79915
25230-5T020
25230-18A00
5-pin
NO/NC with Common pin - open spade 25230-W1300 25230-C9900 25230-C9905 25230-C9907 25230-C9963 - - -||
6-pin
25230-79963 25230-C9925 25230-C9963 25550-25004
C99
NO/NC open spade
25230-C9910
25230-C9915 15A
NO/NC h-shape connector
25230-0B010
25230-81W00
25230-C9962 15A
25230-C9972
25230-C9973
NOx2 open spade 25230-C9920 25230-C9925 25230-C9927 -|| -||
C9920
Misc
15A 25230-79978 20A 25230-79962
24V 25230-0B060
24V 25A 25230-04G00
25230-89915
6-pin connector
Superceded by #B5230-89985
25230-89915ᴳ RELAY ASSY-AUTO CHOKE $24.57 USD
* 1200 Passing Lamp relay * B310 Choke Wiring * 510 Headlight Relay
25230-899151200 JIDECO MR3-011-1
B5230-89985
6-pin spade connectors, Normally Connected + Normally Open
B5230-89985ᴳ supercedes:
- #25230-89915; 25230-89918; 25230-89964; 25230-H6202; 25230-N4300; 25230-N5310; 25230-R0100; 25230-U2000; B5230-89918; B5230-N4300; B5230-N4400; B5230-N5310; B7000-N8501KT
- Used from 1972-1984
- Used by 280Z, 280ZX, 1972-1973 510, 1975-1976 610, 1975-1979 710, 1978-1981 810, 1984 910 Maxima GL
- S30 ignition/fuel pump RELAY B
B5230-899851200 square relay (#C99?) with 6-pin mini-harness
Original part #25230-89915 has built-in 6-pin connector
Alternative? 25230-899051200 JIDECO RELAY type K5
- 510 horn relay
- 510 headlight relay (some models)
25230-89918
- 25230-89918 ASSY-RELAY AUTOMATIC 1972-1/2 to 1973
