510
Revision as of 21:52, 8 March 2025; view current revision
Category: Nissan Vehicles
1967-1972 Datsun model series 510 was marketed as Bluebird in the home market, and 180B in the worldwide market. 510 was Datsun's compact car (C-segment), being larger and heavier than the Sunny 1000 subcompact (A-segment).
See also: 510 Parts Donor
Datsun model series 510 was marketed in Japan as the Bluebird, in America as the 510 and in some countries as 1300/1400/1600 depending on#engine. In all cases, the engine compartment chassis ID plate says "510" regardless of the badges on the car.
Datsun's state-of-the-art car
6529.jpgAlbum 6529
510 was the first Bluebird with unit-body construction (model 410 had an old-fashioned full frame). 510 had modern suspension with front McPherson Struts and IRS (Independent Rear Suspension) on most models. It was the first Datsun light car with Overhead Cam Engine (L-series engine).
510 was Datsun's compact model, being 0.6 inches wider than the sub-compact B210.
8088.jpgAlbum 8088
JDM Datsun 510 Bluebird
The 510 was Datsun's most successful sedan racer
12550.jpgAlbum 12550
Engines
All 510 came with four-cylinder L-series engines. Since the B110 Sunny Excellent came with the L14, all L-series engines are fairly easy to [into a Datsun 1200].
 510 1300 L13 (1296cc) base engine
N510 1400 L14 (1428cc) New engine
P510 1600 L16 (1595cc) Power engine
H510 1800 L18 (1770cc) Hi-line engine
Body Styles
BODY STYLES
 510  4-door Sedan
 510R 2-door Sedan
K510  2-door Coupe (semi-fastback design)
W510  4-door Wagon
V510  4-door Van
10177.jpg4-door sedan 1072.JPG2-door Sedan 16063_502d91231ffd1.jpgCoupe 4964.jpegVan/Wagon
4-door Sedan
7789.jpgAlbum 7789 2790.jpgAlbum 2790 2789.jpgAlbum 2789 2787.jpgAlbum 2787 859.jpgAlbum 859 1043.jpgAlbum 1043 1044.jpgAlbum 1044 2791.jpgAlbum 2791 2793.jpgAlbum 2793 2866.jpgAlbum 2866 3509.jpgAlbum 3509 3797.jpgAlbum 3797 6907.jpgAlbum 6907 6910.jpgAlbum 6910 6911.jpgAlbum 6911 6912.jpgAlbum 6912 10177.jpgAlbum 10177
2-door Coupe
2-door Sedan vs 2-door Coupe (semi-fastback}
10135_50344321a1ed4.jpgPost 416008
K510 Coupe is a fastback 2-door
3989.jpgAlbum 3989 4063.jpgAlbum 4063 12059.jpgAlbum 12059 16063_502d91231ffd1.jpgPost 415626 16063_502d912ca96b5.jpgPost 415626 16063_502d913e713d6.jpgPost 415626
K510 Coupe (silver car) at DATNATS 2011
23045.jpgAlbum 23045
2-door Sedan
510R - 2-door Sedan is a notchback 2-door
1072.JPGAlbum 1072 2219.jpgAlbum 2219 1200.jpgAlbum 1200 4014.jpgAlbum 4014 4015.jpgAlbum 4015 9398.jpgAlbum 9398 13464.jpgAlbum 13464 6906.jpgAlbum 6906
Wagon
VB510 (V = Van)
WB510 (W = Wagon)
11120_49da8b65a0c5d.jpgPost 250047 11120_49da8b6fe9c16.jpgPost 250047 4964.jpegAlbum 4964 11120_49d951dc586d9.jpgPost 249936 11120_49d951e490997.jpgPost 249936
Trims
Japan-market trims
 S   Standard ステンダード
 DX  Deluxe デラックス
 GL  グランド ラクシシェリー (Grand Luxury)
#SSS SU型 ツイ ンカブレター (スーパース ポーツ セダン及びクーペ)
    SU-type Twin Carburetor (Super Sport Sedan and Coupe)
SSS
SSS was the top trim level in Japan. Similar to the GX, the SSS had the Hitachi Twin Carb system with SU-type carburetors.
SU型 ツイ ンカブレター (スーパース ポーツ セダン及びクーペ) SU-type Twin Carburetor (Super Sport Sedan and Coupe)
SSS badges included grille, C-pillar and boot
Custom Roadster
Hainz Washington roadster (not a convertible)
4031.jpgAlbum 4031 newowneryellow510.jpg.ff2ae7e590bcc323aa72f02cddeb524f.jpg
Sold by Hainz in 2017 for $5,000 USD to Eric Edwards. Last seen 2018 in the Enumclaw, Washington area.
Following data is complied from the old Ozdat web siteᴬᴿᶜᴴᴵⱽᴱ
Datsun 1600 convertible owned by Hainz Perry. This 1969 4-door 510 was originally built the early 1980s by Andy Aker in Renton, Washington USA. An unknown owner had the top cut and frame reinforced inside & underneath. Hainz purchased this car frome Eric Edwards [sometime prior to 2001] and had the car rebuilt (front end) after a collision.
  • Owner: Hainz Maui Perry - Kent/Covington, Washington USA
  • L18 engine with flattop pistons
  • A87 cylinder head
  • NISMO Comp (1.5") Manifold with Mikuni PHH44 carburetors
  • Neely Motorsprt box flares kit
  • 510 SSS grille
  • 2-bulb turn signals
  • KOENIG Seats
  • Autopower roll bar
  • Datsun 510 4-speed transmission 63-series
  • Datsun 240Z R200 LSD
  • Wheels: COMPOMOTIVE 3pcs wheels 8x15 front, 10x15 rear
  • Tires: Yokohama AVS tires
Custom Ute
One-off custom 510 Coupe Utility
11120_49d951bd56bba.jpgPost 249936 11120_49d951c88cb93.jpgPost 249936 11120_49d951ec4034d.jpgPost 249936
Late interior | L16
1075.jpgAlbum 1075 1074.jpgAlbum 1074
Custom
SR Turbo 510 (SRT510 plates)
6768.jpgAlbum 6768
Stamm-mobile
RED DEVIL Stamm-mobile with 15" Simmons V4 wheels
10457.jpgAlbum 10457 10459.jpgAlbum 10459 10458.jpgAlbum 10458
CA18-powered 510
510 with CA engine swap
16442.jpgAlbum 16442 16443.jpgAlbum 16443 16444.jpgAlbum 16444 16445.jpgAlbum 16445
FJ Power
FJ20 Turbo engine
6915.jpgAlbum 6915
