Engine Bay
Revision as of 17:19, 9 March 2025; view current revision
Category: Engine Bay
The Datsun 1200 has a small Engine Compartment — as is fitting for its optimized lightweight design. Yet still there is plenty of room for maintenance. Nissan calls it the engine room and many people call it the engine bay.
ID
#B10 (quick ID: No strut towers)
6477.jpgAlbum 6477
#B110 (quick ID: bonnet seal is above the wiper motor)
1759.jpgAlbum 1759
#B210 (quick ID: bonnet seal is below the wiper motor)
17200.jpgAlbum 17200
#B310 (quick ID: bonnet seal is low and nearly flat)
7330.jpgAlbum 7330
Measurements
Approximate measurements follow. They are hand measured, so the accuracy is fair, but the precision is questionable.
B110 Datsun 1200
  • 36.5": Width between Strut shafts at top
  • 30.75": Width between strut tower faces at A12 rocker cover height
  • 26.25": Length from firewall to radiator mounting surface
    Firewall measured behind engine, above the tunnel
  • 27.12": Length from core support header to firewall
    firewall measured at raised boss
  • Width between subframe rail faces:
Comparision
#B10 (Datsun 1000)
4240.jpgAlbum 4240
#B110 (Datsun 1200)
374.jpgAlbum 374
#B210 (Datsun 120Y/140Y/Sunny)
#B310 (Datsun Sunny/210/120Y/130Y/140Y/150Y)
220.JPGAlbum 220
Bay Lower Cover
For aerodynamics.
B10
B10 (Datsun 1000) more photos
4240.jpgAlbum 4240 6477.jpgAlbum 6477 19373.jpgAlbum 19373
B110
B110 (Datsun 1200)
DSC02594.jpg 374.jpgAlbum 374
1759.jpgAlbum 1759 10463.jpgAlbum 10463 17910.jpgAlbum 17910 25782.jpgAlbum 25782 25785.jpgAlbum 25785 5123.jpgAlbum 5123
14608.jpgAlbum 14608
B210 Datsun Sunny 3rd-gen (marketed as 120Y in some markets)
1928.jpgAlbum 1928 3131.jpgAlbum 3131 3283.jpgAlbum 3283 17200.jpgAlbum 17200 25454.jpgAlbum 25454
B310
B310 Datsun Sunny/Datsun 210
220.JPGAlbum 220 6800.jpgAlbum 6800 7330.jpgAlbum 7330 174_5765f22809e26.jpgPost 479336
