Doors
Revision as of 08:57, 4 June 2010; view current revision
Category: Body
Datsun 1200s come in 2-door, 3-door, 4-door and 5-door models.
Also see: Glass including window winders and regulators
4-door
Four door models include the 4-dr Sedan and 5-dr wagon.
2-door
Datsun 1200 2-door models include Sedan, Coupe, 2-dr wagon, and pickup versions.
  • 2-dr Sedan and 2-dr coupe are long doors (same door bottom, different glass frames
  • 2-dr wagon and Pickup use short doors (of 4-dr sedan type)
Fiberglass
  • ProdBodies formerly Japco - fibreglas hood, fenders, flares, door, trunk, spoiler, air dam
Coupe vs Sedan 2-drs
2-dr Coupe and 2-dr Sedan door stampings are the same, but the door window frame differs. These photos of coupe doors test-fitted to a sedan so vividly illustrate the difference, which is about 3 cm in height:
Drain Plugs
These drain plugs fit all Datsun 510, 1200, 620, and 280ZX. The plugs fit on the underside of the doors (2 per door). They help prevent rust by letting water out, and keeping mud from coming in.
Door Panels
  • 2-dr sedan
  • Coupe
  • Ute Early (1971-1977)
  • 4-door Rear
287.jpg 3836.jpg 5039.jpg 7272.jpg 7273.jpg 7569.jpg 8801.jpg 8802.jpg 8812.jpg 9148.jpg 10150.jpg 10653.jpg 11179.jpg 12630.jpg 12756.jpg 18647.jpg 18648.jpg 18649.jpg 18650.jpg 19045.jpg
Escutcheons
The chrome escutheon fits behind the interior door latch handle. Right and left units vary in the where the fitting screw hole is drilled, and where the rubber anti-rattle nub is fitted.
  • 80510-H1000 ESCUTCHEON-REMOTE CONTROL RH NLA
  • 80511-H1000 ESCUTCHEON-REMOTE CONTROL LH NLA
Exterior Handles
As you pull up on the door handle, it raises the latch rod. The rod snaps into the plastic 'holder' bushing.
  • 80605-H1901 ASSY-HANDLE DOOR OUT SIDE FRONT RH $11.83 USD
  • 80606-H1901 ASSY-HANDLE DOOR OUT SIDE FRONT LH $11.78 USD
    • superceeded -H1001
      • superceeded -H1000 (up to March 1971)
    • 08911-10537 NUT (2 per side)
    • replaced 0221-00023
Handle part numbers includes all these:
  • 84371-H1000 HOLDER-OUTSIDE HANDLE JDM
  • 24220-H6200 HOLDER-NYLON USA
    • superceeded 24220-H1000
  • 80608-H1000 ASSY-ROD OUT SIDE HANDLE
    • includes:
    • 80609-E6000 NUT-OUTSIDE HANDLE JDM
      • USA used:
      • 08915-13510 WASHER-SPRING LOCK
      • 08915-43510 WASHER-PLAIN M5
      • 08911-10510 NUT-HEX M5
This one has the simpler type of nylon rod holder.
Interior Handles
B110 DX vs B310
  • 80940-H1100 B110 COMP-ARM REST BLACK #766 $36.65 USD
  • 80940-H1100 B210 COMP-ARMREST (BLACK) [B210 Front and Rear doors]
  • 80940-H1100 620 (BLACK) OPTION to 0678, standard equipment from 0778 USA
  • 80940-B9501 620 (BROWN) OPTION to 0678, standard equipment from 0778 USA
  • 80940-B9700 620 (BLUE) OPTION to 0678, standard equipment from 0778 USA
  • 80691-A0800 510 DX black with chrome strip
B110 STD 'door pulls'
  • 80960-H1001 HANDLE-PULL B110 JDM
  • 80960-H1001 620 USA standard equipment to 0678
  • 80960-H1001 620 from Jul 1969 USA
B310 STD door pulls
  • 80960-H8800 HANDLE-PULL(BLACK)
  • 80960-H8500 HANDLE-PULL(BROWN) to 0779
  • 80960-03W01 HANDLE-PULL(BROWN) from 0879
B310 DX armrests (front doors)
  • 80940-W5000 ARMREST ASSY-DOOR (BLACK 021G0)
  • 80940-H9100 ARMREST ASSY-DOOR (BLUE 021B16) to 0779
  • 80940-H9101 ARMREST ASSY-DOOR (BLUE 021B27) from 0879
  • 80940-H8500 ARMREST ASSY-DOOR (BROWN 021C3) to 0779
  • 80940-01W01 ARMREST ASSY-DOOR (BROWN 021C5) from 0879
Above Door Fittings
  • 73940-H1101 B110 ASSY-RAIL ASSIST, also 620 OPTION
    • From 0778 620 OPTION 73940-B9800
  • 73940-H5000 B210 ASSY-ASSIST GRIP (GRAY, VK-204)OPTION
  • 96750-H5000 B210 HANGER-COAT (GRAY,#1618)
  • 73940-H8501, 73940-W5800 (various) ASSIST GRIP ASSY
  • 96750-H8500 (various) HANGER-COAT
Latch
It seems the latches is identical between 2-dr sedan, 4-dr sedan and Coupe. But there are right and left-hand parts.
The rod on the right of this photo is to the Lock Cylinder. If turning the Key won't move the knob far enough to lock or unlock, trying bending this rod:
The other rod (which goes straight up) is to the interior lock Pull Knob
Parts
The B120 diagram here is almost identical to the Coupe, except that the insulator (80504F) is not used on the other models. The part numbers are mostly the same as Coupe, except for the latch and striker.
Coupe and 2-dr Sedan are identical.
4-dr sedan parts are mostly different, but the latch itself, escutcheon, and inside door handle (remote control) is the same on front doors. The striker and door handle are different.
  • 80760-H1000 ASSY-HANDLE DOOR WINDOW REGULATOR $24.00 USD
  • 80502-H3600 ASSY-DOOR LOCK FRONT RH $128.10 USD
    • formerly 80502-H1201
  • 80503-H3600 ASSY-DOOR LOCK FRONT LH NLA
    • formerly 80503-H1201
Hinges
Interior lock knob
  • 80595-21003 KNOB-DOOR LOCK [black]
    Custom chromed:
  • 80595-N1600 KNOB-DOOR LOCK replaces 80595-21003
    • From 1972 510 line
B210 has wedge shaped knobs
Exterior Lock
See Keys
Scissor Doors
"Lambo" style doors on Datsun 1200.
See main article: Flip-up Doors
1239.jpg 1915.jpg 3302.jpg 4467.jpg 4838.jpg 4840.jpg 6248.jpg 8358.jpg 8361.jpg 8960.jpg 9800.jpg 10883.jpg 10884.jpg 11056.jpg 11084.jpg 12094.jpg 12095.jpg 12096.jpg 15195.jpg 15266.jpg 15267.jpg 16764.jpg 16783.jpg 16784.jpg 17027.jpg 17028.jpg 17566.jpg 17696.jpg 17728.jpg 17729.jpg 17753.jpg 18055.jpg 18708.jpg 18709.jpg
