Brakes
Revision as of 03:25, 10 June 2010; view current revision
Category: Brake System
Datsun 1200s came with two brake systems: all drums (Standard models), or front disc with rear drums. They were excellent brakes for the period. All are manually adjusting except non-North America Left-hand drive 1200s, which were equipped with auto-adjusting rear drum brakes.
Also see:
Types
The 1200 front-disc/rear-drum system was good for 1971. In fact, stopping power was better than most 'muscle cars' of the era. However, if you have a drum/drum system, you'll want to upgrade to disc/drum. The drum system stops well enough, but the disc system has less fading going down mountain roads.
Calipers
Calipers are used with disc brakes. Datsun B110, B210 and B310 used floating two-piston ANNET types.
Type
  • B110: ANNET 12/14A (1.894" cylinder inner diameter)
  • B310 small: AN-18 (1.894" cylinder inner diameter)
  • B310 large: Disc-AN20 (2.012" cylinder inner diameter)
Caliper bolt spacing:
  • ~84 mm: B110
    • and all 12" wheel B210 and B310
  • 88.9 mm: B310 large struts for 13" wheels
Rotor Sizes
Dia. (mm)Part NumberSource
212.540206-H1006B110, B210 with A12 1974, 1975
220 (AN18)40206-H7500B210 A12 1976-1978,B310 with 12" wheels
23240206-A1155B210 A13, PB110?, PB210 early?
245 (AN20)40206-U6700A10, B210 A14, B310 A14/A15, PB210 late?
??B210 Australia-assembled
? (Girlock)?A10, Australia-assembled
Rear Drum Brakes
The same rear brake drum was used 1967-1994. It is an 8" diameter cast iron drum, that fits 1-3/8 wide brake shoes. Sunny Trucks started using a different brake shoe from Oct 1989.
Specs
  • Linings (shoes)
    • 35 x 4.8 x 195 mm (width x height x thickness)
    • 1.378 x 0.189 x 7.68 inch (W x H x T)
    • 1-3/8 x ~3/16 x ~7-11/16 inch (W x H x T)
  • Total breaking area: 273 cm² (42.3 sq. in.)
  • B110: (manual adjusting)
    • Cylinder: 11/16" with front discs
    • Cylinder: 13/16" with front drums
  • B310: Drum LT-20 (auto adjusting)
    • Cylinder: 13/16" (20.64 mm)
1978-1989 B120 ute used rear type Drum-LT20 with front type Drum2L20.
Finned Alloy Brake Drums
  • The fins look like structural type, not cooling type.
quote
Datsun Competition Dept supplied it's favoured teams with many experimental parts that were never sold over the counter. 1200s had alloy drums and calipers fitted as wellas the alloy diff heads from the wagons.
  • Finned drums like these were offered by Datsun Competition in Japan.
brake cylindersB110 (disc)1977 US B2101980 US B310 (Disc-AN20)1980 Canada A12A (Disc-AN18)
Proportioning valvenot usedyes1,961 kPa x 0.4 psi1,961 kPa x 0.4 psi
Booster (Master-Vac)not used?M60 6-in diameter 135mm rod length (flange-to-pedal)M60 6-in diameter
Master diameter11/16 inch3/4 inch13/1613/16
Front cylinder diameter1.894 inch (drum brakes: 11/16)2.012 inch2.012 inch1.894 inch
Rotor diameter212.5 mm245mm245mm220mm
Pad (width x length)42.5 x 53.1 mm41.2 x 63.4 mm41.2 x 61.4 mm42.0 x 56.8 mm
Pad thickness10.310.010.010.3
Total front braking area (discs)14.0 sq in16.2 sq in~14.6~13.8
Total front braking area (drums)42.3 sq inn/an/an/a
Rear cylinder diameterdisc brake models: 11/16 inch (all-drum models: 13/16)13/16 inch13/1613/16
Drum diameter8.0 inch8.0 inch8.08.0
Drum width1.378 inch1.378 inch1.3781.378
Total rear braking area42.3 sq in42.3 sq in42.342.3
http://www.rockauto.com
Front Brake Hoses
  • Length=11" End A Size=M10X1 End B Size=M10X1
  • RAYBESTOS BH36892; DORMAN H96862; ACDELCO 18J2188, 18J126, 19173109
Rear Brake Hose
  • Length=13.188" End A Size=M10X1 End B Size=M10X1
  • RAYBESTOS BH36866; DORMAN H36866
Pads
See Brake Pads
Rear Brake Shoe
set (8 x 1-3/8, fits B110, B210 and B310)
  • RAYBESTOS 371PG $15.36
  • WAGNER PAB371 $16.52
  • ACDELCO 17371B $19.02
  • WAGNER BD60368 $39.89
Rotor
  • Front disc inner wheel bearing {Taper Bearing Assembly / Cone Length=0.5906 Bore=0.9843 Outer Diameter=2.0472 Width=0.6398 Cup Length=0.5118 Cone Radius=0.06 Cup Radius=0.06}
    • BECK/ARNLEY 0513809 $13.61
    • BCA 30205 $14.73
Wheel Bearings
Rockauto.com
FRONT INNER
Same bearing is used on drum brakes and disk brake hubs.
Nissan 52 mm O.D.
  • 40210-H1000 ASSY-BEARING FRONT WHEEL INNER from 0570
  • 40210-18000 ASSY-BEARING FRONT WHEEL INNER to 0470
    • BCA/NATIONAL 30205
    • TIMKEN 30205M
Specs: Taper Bearing Assembly
  • Cone Length=0.5906"
  • Bore=0.9843"
  • Outer Diameter=2.0472"
  • Width=0.6398"
  • Cup Length=0.5118"
  • Cone Radius=0.06" Cup Radius=0.06"
FRONT OUTER
Nissan 42mm O.D.
  • 40215-H1000 ASSY-BEARING FRONT WHEEL OUTER from 0570
  • 40215-18000 ASSY-BEARING FRONT WHEEL OUTER to 0470
    • BCA/NATIONAL 30302
    • TIMKEN 30302
  • Cone Length=0.5118"
  • Bore=0.5906"
  • Outer Diameter=1.6535"
  • Width=0.561"
  • Cup Length=0.4331"
  • Cone Radius=0.06"
  • Cup Radius=0.06"
Rear Wheel Bearings
See Axle Shaft. These are not easily replaced.
Caliper
  • Bore Size=1.89" Inlet Thread=M10X1 Bleeder Thread=M10X1
  • Right: RAYBESTOS FRC3021 $30.79, RC3021, A-1 CARDONE 19124, 17124
  • Left: RAYBESTOS FRC3022 $30.79, RC3022, A-1 CARDONE 19125, 17125
Parking Brake Cable
  • 48-1/4" Overall Length, 2 Per Car
  • RAYBESTOS BC92888 $39.79
  • ACDELCO 18P154, 18033072 $48.79
Master Cylinder
  • Bore Size=11/16" Number of Ports=2 Primary Outlet Size=M10x1 Secondary Outlet Size=M10x1
  • A-1 CARDONE 111655 Remanufactured $26.79
  • RAYBESTOS MC39087
  • ACDELCO 18M1072, 19106858
B120
Front Disk Brakes from 8910. These are unique as they fit the same strut as the former drum brake setup.
Rear Drum Brake
  • 44060-G0300 SHOE ASSY-REAR BRAKE SHOE 7510-7611
  • 44060-G0325 7612-8910
  • 43206-18000 DRUM BRAKE-REAR
  • 44060-G1225 8910-
1980 10 and newer Sunny Truck feature auto-adjust rear brakes:
Master Cylinder
Master cylinder has two bolts in horizontal plane; previous drum brake system used two bolts in vertical plane (like B110).
Front Discs
  • 41060-G1985 PAD KIT-DISC BRAKE
  • 41001-G1500 CALIPER ASS'Y-FRONT RH W/O PADS OR SHIMS [Floating caliper]
  • 41121-05A10 PISTON-CYLINDER $31.23 [~1.8 inch (~45.2 mm)]
    • Pulsar SE 1988-1989
    • NX SR20DE, w/o abs 1991-1993
    • Sentra, gasoline, wagon 1988-1989
    • Sentra, SR20DE 1991-1994
  • 47210-G1500 BOOSTER ASSY-BRAKE
  • 40207-G1501 ROTOR-DISC BRAKE, FRONT [232 mm?]
Nissan Competition
  • 44060-A1260 SHOE ASSY-Brake Fore for LT20 Drum, Ferode AM4
  • 44060-A1270 SHOE ASSY-Brake After for LT20 Drum, Ferode AM4
  • 44100-M7000 CYL ASSY-Wheel 5/8" LT20 Selective Use, N10 standard
  • 44100-M4901 CYL ASSY-Wheel 11/16" LT20 Selective Use
  • 44100-G2800 CYL ASSY-Wheel 1/4" LT20 Selective Use
  • 44100-U9200 CYL ASSY-Wheel 13/16" LT20 Selective Use
