B10 Lights
Revision as of 10:24, 30 September 2010; view current revision
Category: Datsun B10
Datsun 1000 tail lights vary by model and country.
Indicators
Datsun 1000 was fitted with different indicator lamp lenses depending on the year and trim.
Front Guards
  1. 1967 Model: Small Round dome type
    • 26161-18000 LENS-lamp
    • Looks similar to 510 rear USA (EVER WING A3036 SAE P167), but this is much flatter. The B10 lens sticks out quite a bit.
  2. 1968, 1969: Short spear
    • about 10cm long
    • 26161-25700 LENS-lamp (from C/# B10-80026, VB10-84001)
  3. 1970: Long spear (13cm+). Same as Datsun 510 "1600"
    • Replaces spear A
    • 26161-A4600 LENS-lamp (from C/# B10-350001, VB10-240001, KB10-80001, B20-61001)
      • JDM & ADM 510s
      • These look similar but are asymmetric:
        • 26161-21000 ASSY LENS WITH RIM RH 1068- USA
        • 26166-21000 ASSY LENS WITH RIM LH -0969 USA
Datsun 521 pickup in USA uses a spear that looks similar.
Repeater%20Assembly%20(26160-B0101).jpg Datsun 521 part number 26160-B0101 is identical to the 1000 1968/1969 short spear lamp.
Coupes uses same lense as others, but the assembly (lamp housing) is different for Coupe.
Position
Late Ute
Front Lamps
Datsun 1000 was fitted with clear lens front combination lamp.
Australia
Aussie models had a orange bulb offset to the inside of the lens???
  • clear rectangular lense A
  • clear rectangular lense B
  • Coupe: Large Amber lens
  • 2-section (amber + clear)
Front%20Indicator%20Assembly%20-%20Left%20(%27Everwing%27%20EW6030L).jpg Left Light Assembly.
Front%20Indicator%20Amber%20Lens%20-%20Right%20(26122-20900).jpg 26122-20900, Right Amber Lens.
Front%20Indicator%20Rubber%20-%20Right%20(26123-27750).jpg 26123-27750, Right Gasket.
Japan-market. Clear lens with orange-bulb centered.
  • 26121-18000 LENS-parking & turn signal (R.H.) ALL except Coupe [Clear lens, Single bulb]
  • 26121-27700 LENS-parking & turn signal (R.H.) ALL except Coupe [Clear lens, Single bulb]
  • 26121-25702 LENS-parking & turn signal (R.H.) Coupe [Clear lens, Single bulb]
Position
  • Sedan, Van, Ute: Fitted below the headlight, above the bumper
  • Coupe: Fitted below the bumper
Tail Lights
Datsun 1000 rear lamps were combination type.
Sedan
B10 Sedan rear lamps came a in a few styles.
Amber inside
Red inside
Amber outside
1969-1970
Coupe
KB10 taillights came in this style.
Wagon
Pickup
B20 Pickup
