Nissan Skyline model R31 was built in Japan 8508-9005. It was fitted with a Four Cylinder CA engine, or six-cylinder RB engines, or a Diesel. Australia-built R31 1986-1990 was sold as Skyline (six-cylinder) or Pintara (four-cylinder). Some parts can be use, or modfied for use, on a a Datsun 1200.
Engine
JAPAN F CA18S H RB20E/RB20ET SOHC R RB20DE/RB20DET DOHC S RD28 diesel
AUSTRALIA Skyline: Holden RB30E Pintara: CA20E (NAPSX) SOUTH AFRICA built CA20S RB20E RB30E
Wheels
R31 Skyline 14" steelies. See [[Wheels#Skyline R31 spare steel wheels
Front Brakes
Strut
Diff
JAPAN R31 H190: CA18S Sedan, Hardtop, Wagon CA200: Wagon RB20T [4.11, 8601-] R200: RB20, RD28 Sedan, Hardtop [IRS]
AUS R31 Borg Warner BW78: Pintara, has rear disc brakes 10-bolt octagonal cover 25-spline axles
AUS
Series II Silhouette LSD![]()
Rear Discs - see R31 Australia![]()
R31 Skyline![]()
Swapping into 1200
You can swap a narrowed axle into a 1200.
CA200
JAPAN R31 Wagon with RB20T SOHC Turbo 1986-1990 * (build dates 8601-9005) CA200: Wagon RB20T [4.11 (CA41), 8601-] * Drum brakes * 5-link with coil springs * 4-lug, 28-spline(?) axles
CASE-DIFFERENTIAL * 2-pinion * M12 ring gear bolts * Fits: CA41,CA43,CA46,CA48,RC35,RC37,RC39,RC41,RC43,RC46 38421-12S00 8601-8708 38420-P9400 8708 <2> 38420-12S10
CA41 37/9=4.111 38100-F3400 8601-8604 38100-F3401 8604- $677 USD
SHAFT ASSY-REAR AXLE 38162-42L00 * R31 with CA18S * R31 Wagon * C32 some * GC22 Vanette 8605 2WD
DRUM-BRAKE,REAR 43206-U4800
43010 CASE ASSY-REAR AXLE 43005-84S55 HOUSING W/GEAR <2> 43005-84S56
38423 GEAR-SIDE 38423-C6100 * (G)C22,D22,E23,E24,F22,F23,R31,WD21,160,250,
Alternative for swaps: GC22 Vanette - CA200 w/LSD
