Seats
Revision as of 23:44, 7 July 2007; view current revision
Categories: Body | Interior Modifications
Stock Seats
11913.jpg USA Coupe 5083.jpg Stock Seats 11899.jpg Stock headrests
1555.jpg Standard, Deluxe and Reclining Seats
456.jpg GX Seats
620.jpg DX Seats
765.JPG Recovered Seats
Aussie-Market Seats
3537.jpg 1200 Coupe seats (custom fabric) in Datsun 1000
Seat Riser Trim
The seat riser trim is the little plastic pockets next to the doors.
TRIM-SEAT RISER, RH
  • 74961-H1100 7510-7803 BLACK
  • 74961-G1060 7804-8910 DARK BROWN
  • 74967-95W00 8910- GRAY
TRIM-SEAT RISER, LH
  • 74962-G1000 7510-7803 BLACK
  • 74962-G1060 7804-8910 DARK BROWN
  • 74968-95W00 8910- GRAY
CLIP-TRIM (4 needed)
  • 66919-H1001 7510-7803 BLACK
  • 66919-G1060 7804-8910 DARK BROWN
  • 96815-B0700 8910-
Alternative Seats
3792.jpg Cobra Seats
3577.jpg Monza Seats
2885.jpg Mazda 121 Seats
1326.jpg Corolla Seats
1075.jpg Recaro Seats
1731.jpg Ford Laser Seats
1993.jpg Honda Prelude Seats
2386.jpg Seat Covers
2017.jpg Daihatsu Seats
2974.jpg Buff's Seats
4212.jpg EFI Seat
Racing Seats
1467.jpg Yokohama Seats
2617.jpg Revolution Racegear Seats
1897.jpg Baby Seat
2984.jpg SAAS Buckets
3481.jpg Sparco Buckets
4727.jpg OBX Daytona Buckets
3862.jpg Velo Seats
Adapting Seats
B210 seats and B310 seats will fit right into the B110. Just unbolt the rails from your seats and bolt them to the new seat:
5185.jpg Seat Slide (aka Seat Rail)
If you don't have the B110 rails, you can adapt B210 or B310 slides:
5086.jpg Modifying B310 brackets to fit B110 chassis
Many, many other seats will fit into your Datsun 1200. You can use flat plates to adapt the 1200 rails to the new seats:
5186.jpg Seat Adapting
554.gif Seat Slide
573.gif Seat Rails
574.gif Seat Rails
5085.jpg Chassis Brackets - for flat seat runners
9731.jpg 323 seats in 1200 coupe
Account and pictures of how to adapta Civic seats: http://forum.ratsun.net/showthread.php?t=776
Rear Seats
4927.jpg B310 Sedan rear seat in B110
5042.jpg B110 Coupe Rear Seat
Australia Legalities
