Console
Revision as of 00:00, 29 July 2015; view current revision
Categories: Interior | Fibreglass
Datsun 1200s were fitted with various consoles including full-style and compact style.
Full Size
Full size console was usually fitted with a Clock. The Tachometer was rightly fitted into the dashboard, but you can put the tach in the console if you so choose.
5703.jpg 21473.jpg :full
21478.jpg Brackets
592.jpg w/o heater
6595.jpg SSS
1970-1971 appears to be gold tinted, while 1972 seems to be silver-tinted. But the GL brochure shows what looks like a black tinted console. The catalogs show only two numbers: early and 1972.
th_gsi.jpg GL 460.jpg GX Facelift
25955.jpg th_lc1.jpg th_lc2.jpg th_lc3.jpg th_lc4.jpg th_lc5.jpg th_lc6.jpg th_lc7.jpg th_lc8.jpg th_lc9.jpg th_lca.jpg th_lcb.jpg th_lcc.jpg
Consoles assemblies come with Clock mask, Clock is sold separately.
Sunny 1200 Optional Parts catalog
* 74980-H2010 ASS'Y-CONSOLE BOX (大型 large type) GL/GX manual
* 74980-H2020 ASS'Y-CONSOLE BOX (大型 large type) GL automatic
Japan catalog
1972 Japan [Facelift] catalog
* 74980-H3320 CONSOLE BOX ASS'Y-with bracket GL/GX 4-speed
* 74980-H3330 CONSOLE BOX ASS'Y-with bracket GL automatic
USA Catalog
* 74980-H1801 ASSY-BOX CONSOLE MANUAL -0772
* 74980-H2010 ASSY-BOX CONSOLE COUPE MANUAL 0772-
* 74980-H7000, 74980-H7001 ASSY-BOX CONSOLE MANUAL 0772-
Mask
'Sunny'
74990-H2021 MASK-clock [console]
'Datsun'
74990-H1800 MASK-CLOCK [console]
Compare to simpler Dash blank
The console mask has an aluminum adapter bracket to allow it to bolt to the three console holes.
Clock Fitting
Just unbolt the mask plate, and bolt in the Clock. The same clock fitted in the dash is used in the console.
The second set of tabs - back from the face - are used to bolt into the console
click
If the side-brackets are missing - e.g. a 1976-up clock - you may fabricate a simple bracket to hold the clock in place.
discussion
27389-H2300 SPACER FIXING CLOCK TO CONCOLE BOX OP
25962.jpg  post
If you buy a second-hand clock and end up with the Facelift clock, cut the long bracket off to make it fit in the console:
click
24043-H2000 ASS'Y-CABLE, for console clock GX [extension harness for clock wiring]
Fibreglas
Glassfibre versions
Short Console
The short pocket-type console was fitted to:
* Automatic DX
* OPTION 4-speed 1200s STD and DX
* JAPAN 3-speed column shift OPTION
* B120 Pickups as standard equipment (except STD models)
Brackets (B122 pictured)
Full and short consoles use the same shifter boot.
* G4980-H1025 ASS'Y-CONSOLE BOX [short, OPTION for 3-speed (column shift)]
* 74980-H1801 ASS'Y-CONSOLE BOX, with bracket 4-speed (ex. GL, GX)
* 74980-H1021 ASS'Y-CONSOLE BOX, with bracket A-all (ex. GL)
North America
* 74980-H1921 ASSY-BOX CONSOL SEDAN,COUPE AUTOMATIC
* 74980-H1801 ASSY-BOX CONSOL SEDAN,COUPE MANUAL OPTION
* 74980-H7000 ASSY-BOX CONSOL SEDAN,COUPE MANUAL OPTION 0772- [Fire-resistant?]
B120
* 74980-H1801 CONSOLE BOX KIT-FLOOR W/BRACKET     -7803 [Black]
* 74980-G1160 CONSOLE BOX KIT-FLOOR W/BRACKET 7804-7907 DARK BROWN
* 74980-G1660 CONSOLE BOX KIT-FLOOR W/BRACKET 7908-8109 BROWN
* 74980-G1900 CONSOLE BOX KIT-FLOOR W/BRACKET 8110-8910
* 96910-95W00 CONSOLE BOX KIT-FLOOR W/BRACKET 8910- GRAY
Shifter Boot
シフト ブーツ Boot for shift lever
Aftermarket
Nissan
Finisher
Fibreglas
Glassfibre versions
Aftermarket
Amco aftermarket/dealer installed
Custom
Portugal 1200s. Are the custom consoles?
Documentation
1555.jpg JDM 2209.jpg USA
Alternative Sources
Honda Civic
Barina
Barina
PB110
Sunny Excellent used consoles the similar to B110, but extend up further with vents that drop down in the top. Also these unique 3-gauge versions. For more, see: PB110
2010.jpg PB110
9020.jpg 1971
7712.jpg PB110s could also come with regular-style gauge layout
PB110 console
74990-H2600 MASK ASS'Y-clock ['Sunny'] GL,GA
27380-H2600 CLOCK ASS'Y GX
74982-H2600 MASK-console box body SGA [single hole]
コンソール ボックス ボヂー マスク
74982-H2601 MASK-console box body GX, (op.) Sedan [three hole]
B210 Console
Does not fit the 1200 well
B210 console
74598-H5000
B310 Console
Sold by Bprojects
96935-H8500 BOOT (BLACK)(G) <> 96935-H8560 $35.58 USD
96935-H9160 BOOT (BLUE) 0879- $32.62 USD
96935-H9100 BOOT (BLUE) -0779 $30.12 USD
96935-H8561 BOOT (BROWN) $35.58 USD
838.jpg 1350.jpg 834.jpg 3069.jpg 4748.jpg 4823.jpg 4939.jpg 5619.jpg 9471.jpg 19640.jpg 21466.jpg 21467.jpg 21471.jpg 21472.jpg
click
click
keywords: コンソール
