Sunny Truck Model Changes
Revision as of 07:05, 8 October 2012; view current revision
Category: Sunny Truck
Datsun 1200 Sunny Truck (Nissan Model B120/B121/B122) production in Japan started January 1971 and ended March 1994. In Japan its nickname is ???? ("sanitora"). Common equipment includes:
The following equipment was not offered:
  • No Tachometer
  • No automatic transmission offered
  • No 5-speed transmission (except in RoadStar/SportStar B120)
  • No A14 (except in South Africa B140 truck)
Chassis ID Numbers
Applied Model code: G16
  • B120T to 7907
  • GB120T to 7907 Long Body (long bed)
  • B121T 7908-8109
  • GB121T 7908-8109 Long Body
  • B122T 8110-
  • GB122T 8110- Long Body
1970-1977
B120
Same as Datsun 1200 Standard trim cars:
  • Black interior
  • H145 rear axle assembly
  • Front Drum brakes
  • Stainless grille (same as sedan/wagon)
  • Standard dash
  • EVAPO Flow Guide Valve (same as USA models)
  • Gray wheels
  • 'Sunny' sedan-style rear quarter badges (to 8102)
  • Disc Wheel Caps (dog-dish hubcaps)
  • Silver-trimmed rear tail lights
From May 1973
  • Tandem master cylinder
  • Long Body (??? ??) debuts, 295 mm longer
  • fuel and equipment employed to prevent evaporation (EVAPO)
from 1974:
  • H165 rear axle assembly
Oct 27, 1975
  • 50 relevant regulations of emissions.
  • Nissan catalyzed oxidation of exhaust gas cleaning system "NAPS" adopted
1978 - 1988
B120 to 7903, B121 from 7908, B122 from 8110
  • Aero mirrors
  • Round gauges
  • Dark Brown interior (7804-7907)
  • Brown interior (7908-8110)
  • Hi-back seats (no headrests)
  • B210-style steering wheel
  • Half-wheel caps abolished (1979 Oct)
  • Intermittent wiper switch
  • black rubber ends on front bumper
  • from 7804: Coupe-style plastic grille -- but with silver surrounds and rectangular center emblem
  • Black-trimmed rear tail lights
From 7901
  • Silver TOPY wheels
From 7908
  • B121 designation
  • New-style intake manifold bolt pattern (dry manifold)
  • EGR added
  • Disk wheel ornaments (Center wheel caps replacing dog-dish)
from 8103
  • Rear label: "Sunny", "Sunny Long Body" block-style
from 8110
  • B122 designation
  • emergency signal holder on passenger side kick panel
  • door pocket
  • New-style VIN plate
  • IC alternator (some)
  • 56-year relevant regulations of emissions
  • Exhaust gas recirculation system (EGR) system improvements
  • Package tray
  • Rear gate chaing with large hook and rope used
From 8504 "Minor Change"
  • Cold Air duct for air cleaner
  • Hood insulator
  • Exhaust Resonator added to meet new noise regulations (Jan 1985?)
  • Silver Nissan wheels
1986 Nov 18
  • laminated glass windshield
  • parking lights removed
  • ELR seatbelts
Press Release
1978.04.18 Sunny Truck Modified Release
launches nationwide April 18
Overview of the major change to the Sunny Truck Series are as follows.
1. Improvements and equipment specifications
(1) Larger cargo hooks.
(2) Adding rubber to the front bumper corners.
(3) Adopting new high back seats, and changing the inclination angle of the seat back.
(4) Adopting intermittent wipers.
(5) Three-point seat belts as standard.
(6) Adopting steering lock, passenger side sun visor, and passing light.
2. Changing the design
(1) Using a molded plastic radiator grille.
(2) Talbot type fender mirrors.
(3) Painted black rims on the rear combination lamps.
(4) Adopting round meters.
(5) Redesigning the steering wheel.
(6) Brown seats, instrument panel, door trim, steering wheel and gearshift knob.
Sales targets 1,800/month
1989- 1994
B122 from 8910
  • Nissan front emblem
  • Front disk brakes
  • Single-reservoir, tandem master cylinder
  • Brake booster
  • New rear brake design (still using B10 brake drum)
  • Gray interior
  • Rear label: "Nissan"
  • Integrated seat/shoulder belt standard (previously optional)
  • Square headlights
  • Electronic ignition
  • Fuse box with rectangular fuses
  • Wet intake manifold
  • Oxygen Sensor 22690-F5300 (electronically controlled carburetor)
    Superceded by 22690-17B00
    Same as Sentra, E16i eng 1984 - 1986
  • Engine Control Module 220604-95W00
  • Catalyst (catalytic convertor). 3-way type.
  • Heated air-cleaner motor
  • Fuel tank with return line
  • Larger muffler and resonator
  • EVAPO Charcoal Canister replaces Flow Guide valve. Rocker cover has right-angle breather outlet
  • Revised F4W56 transmission with Neutral switch
  • 19T gear up from 18T
  • 1991 engine
Trim Code
For 1989-up
Trim code: K (Gray ???)
Seats are gray edged with white inserts. Black mats with raised dots seem to be common.
Body Color
  • #002 White ????
  • #EH3 Dark Yellow ????????
  • #544 Blue????
  • #BG9 Greenish Blue metallic ????????????????
Options
  • Passing light switch & relay
  • Low horn
  • Clock
  • Package tray
  • Carpet floor
  •  ? heater
  • side visor set
From 7804
  • ELR 3-point seatbelts
  • Cooler (air conditioning)
  • hard ??leafspring
  • hard ? starter
  • Guard frame (rear window bars)
Long Body
The Long Body (LB) has these differences from standard short body (SB):
  • Wheelbase is longer
  • Cargo box (bed) is longer
  • Has two-piece drive shaft with Center Bearing (carrier bearing)
  • Front exahust pipe is longer up to 8909
  • longer exhaust system from 8910
  • no resonator from 8910
Emission Controls
  • H-B120T 1976 Jan
  • J-B121T 1979 Oct
  • L- 1981 Oct
  • R- 1989 Oct: NOx PM
Parts
  • 90500-01W00 Back Door Lock Ass'y (tailgate handle) available in USA $27.34
  • 96321-95W00 Inside Mirror $26.43
