Datsun 1000 tail lights vary by model and country.
Side Lights
Datsun 1000 front guard was fitted with different indicator lamp lenses depending on the year and trim.
- 1967 Model: Small Round dome type
- 26161-18000 LENS-lamp
- pic
- Looks similar to 510 rear USA (EVER WING A3036 SAE P167), but this is much flatter.
- The B10 lens sticks out quite a bit.
- 1968, 1969: Short spear
- 1970: Long spear (13cm+). Same as Datsun 510 "1600"
Datsun 521 pickup in USA uses a spear that looks similar.
Datsun 521 part number 26160-B0101 is identical to the 1000 1968/1969 short spear lamp.
Coupes uses same lense as others, but the assembly (lamp housing) is different for Coupe.
Position
Front Lights
Datsun 1000 was fitted with clear lens front combination lamp.
Australia
Aussie models had a orange bulb offset to the inside of the lens???
- clear rectangular lense A
- clear rectangular lense B
- Coupe: Large Amber lens
- 2-section (amber + clear)
26122-20900, Right Amber Lens.
Japan-market. Clear lens with orange-bulb centered.
- 26121-18000 LENS-parking & turn signal (R.H.) ALL except Coupe [Clear lens, Single bulb]
- 26121-27700 LENS-parking & turn signal (R.H.) ALL except Coupe [Clear lens, Single bulb]
- 26121-25702 LENS-parking & turn signal (R.H.) Coupe [Clear lens, Single bulb]
Position
Tail Lights
Datsun 1000 rear lamps were combination type.
Sedan
B10 Sedan rear lamps came in two styles.
180 type: 1967-1969 full
H01 type: 1970 (from October 1969) full
Coupe
KB10 taillights came in this style.
