Datsun 1200s came with two brake systems: all drums (Standard models), or Girling-Tokico front disc with rear drums. They were excellent brakes for the period. All are manually adjusting except non-North America Left-hand drive 1200s, which were equipped with auto-adjusting rear drum brakes.
Also see: * Rear Brakes * Brake Swaps * Brake Upgrades * Brake Adjustment
Types
- Drum front/drum rear - Standard trim, Deluxe trim
- Disc front/drum rear - GL, GX and optional on Deluxe
The 1200 front-disc/rear-drum system was good for 1971. In fact, stopping power was better than most 'muscle cars' of the era. However, if you have a drum/drum system, you'll want to upgrade to disc/drum. The drum system stops well enough, but the disc system has less fading going down mountain roads.
Adjustment/Maintenance
See: * Drum Brake Adjustment * Disc brakes need no adjustment
Calipers
Calipers are used with disc brakes. Datsun B110, B210 and B310 used floating two-piston ANETTE types. These were desinged by Lucas Girling who make the Anette, Babette and Colette series.
Type B110: ANNET 12/14A (1.894" cylinder inner diameter) B310 small: AN-18 (1.894" cylinder inner diameter) B310 large: Disc-AN20 (2.012" cylinder inner diameter)
1200 Brake Rotor Outer diameter: 212 mm Height: 35.6 mm Nominal thickness: 9.5 mm Minumum thickness: 8.6 mm Hub Reg: 70 mm Bolt size: 10 x 1.5 mm Bolt circle: 4 x 87 mm Weight 5.9 - 6.1 pounds
Caliper bolt spacing: 84 mm: B110 * and all 12" wheel B210 and B310 88.9 mm: B310 large struts for 13" wheels
Rotor Sizes
Dia. (mm) | Part Number | Source |
208 | 40207-G1501 | Sunny Truck 8910- |
212.5 | 40206-H1006 | B110, B210 A12 1974-1975 |
220 (AN18) | 40206-H7500 | B210 A12 1976-1978,B310 with 12" wheels |
245 (AN20) | 40206-U6700 | A10, B210 A14, 1976-1978 120Y, B310 A14/A15, PB210 late? |
? | ? | B210 Australia-assembled |
? (Girlock) | ? | A10, Australia-assembled |
Brake Lines
See main article: Brake Lines
Front Drum Brakes
1200 DX and STD trim received front drum brakes (GL and GX were fitted with Disc Brakes). It uses two cylinders, unlike the rear drums which have one cylinder.
* Wheel cylinders: 13/16 inch bore diameter
Rear Drum Brakes
See Rear Brakes
brake cylinders | B110 (disc) | 1977 US B210 | 1980 US B310 (Disc-AN20) | 1980 Canada A12A (Disc-AN18) |
Proportioning valve | not used | yes | 1,961 kPa x 0.4 psi | 1,961 kPa x 0.4 psi |
Booster (Master-Vac) | not used | ? | M60 6-in diameter 135mm rod length (flange-to-pedal) | M60 6-in diameter |
Master diameter | 11/16 inch | 3/4 inch | 13/16 | 13/16 |
Front cylinder diameter | 1.894 inch (drum brakes: 11/16) | 2.012 inch | 2.012 inch | 1.894 inch |
Rotor diameter | 212.5 mm | 245mm | 245mm | 220mm |
Pad (width x length) | 42.5 x 53.1 mm | 41.2 x 63.4 mm | 41.2 x 61.4 mm | 42.0 x 56.8 mm |
Pad thickness | 10.3 | 10.0 | 10.0 | 10.3 |
Total front braking area (discs) | 14.0 sq in | 16.2 sq in | ~14.6 | ~13.8 |
Total front braking area (drums) | 42.3 sq in | n/a | n/a | n/a |
Rear cylinder diameter | disc brake models: 11/16 inch (all-drum models: 13/16) | 13/16 inch | 13/16 | 13/16 |
Drum diameter | 8.0 inch | 8.0 inch | 8.0 | 8.0 |
Drum width | 1.378 inch | 1.378 inch | 1.378 | 1.378 |
Total rear braking area | 42.3 sq in | 42.3 sq in | 42.3 | 42.3 |
ブレーキ
Brake Pedal Switch
25320-H1000 -8109 * Beck/Arnley 201-0288 ** 1987-1988 Dodge Colt ** 1990 Mitsubishi Sigma ** 1985 Mitsubishi Starion ** 1967 Toyota Corona ** Datsun B110/B210/F10/N10/S10, 1974-1978 S30, A10, 620, 810, 910 25320-H8500 8110-
25320-75A00 8910-![]()
Front Brake Cylinder
41100-18000 ASS'Y-CYLINDER, front wheel, fore (R.H.) B10, B110 STD,DX 41102-18000 ASS'Y-CYLINDER, front wheel, fore (L.H.) B10, B110 STD,DX 41101-H1000 CYLINDER ASS'Y, front wheel, after (R.H.) B110 STD,DX
41103-H1000 CYLINDER ASS'Y, front wheel, after (L.H.) B110 STD,DX![]()
Seiken 41101-27700 ASS'Y-CYLINDER, front wheel, after (R.H.) B10 superceded 41101-18000 ASS'Y-CYLINDER, front wheel, after (R.H.) B10 41103-27700 ASS'Y-CYLINDER, front wheel, after (L.H.) B10 superceded 41103-18000 ASS'Y-CYLINDER, front wheel, after (L.H.) B10
Meisan (n & n)
B10 front & rear brake cylinders
フロント ホイール シリンダー
Brake Hoses
See main article: Brake Hoses
Pads
See Brake Pads
Rotor
B310 - 245 mm Height: 35.5 mm Thickness: 10 mm Thinness: 8.4 mm Hub reg: 73 mm 4 x 95 PCD (bolts to hub) weight: 8.56 lb * Centric 121.42002
Wheel Bearings
See Wheel bearings
Rear Wheel Bearings
See Axle Shaft. These are not easily replaced.
Caliper
Bore Size 1.89" Inlet Thread M10 x 1.0 Bleeder Thread M10 x 1.0
Right: RAYBESTOS FRC3021 $30.79, RC3021 A-1 CARDONE 19124, 17124
Left: RAYBESTOS FRC3022 $30.79, RC3022 A-1 CARDONE 19125, 17125
41214-H1007 RING-BIAS Girling 29-1007 or 67932343full
Caliper piston centering bias ring for indirect piston. Fit inside the front Disk Brake Pistons (inner side). Tang of Yoke fits into ring.
Parking Brake
See Hand Brake
Master Cylinder
See Brake Master Cylinder
B120
Front Disk Brakes from 8910. These are unique as they fit the same strut as the former drum brake setup.
Rear Drum Brake
See Rear Brakes
Master Cylinder
Master cylinder has two bolts in horizontal plane; previous drum brake system used two bolts in vertical plane (like B110).
Front Discs
Sunny Truck staring in October 1989 has a disc brake system similar to B11/N12.
See main article: Sunny Truck Disc Brakes
Nissan Competition
Nismo Catalogfor race, rally 41060-H1020 Ass'y pad Front Brake DS11 41060-H1021 Ass'y pad Front Brake M59 44060-27720 Ass'y-Shoe Rear Fore (B10 op.) 44070-27720 Ass'y-Shoe Rear After AM4 (B10 op.) 44100-H2320 CYL ASSY RR Wheel 5/8"
44060-A1260 SHOE ASSY-Brake Fore for LT20 Drum, Ferode AM4 44060-A1270 SHOE ASSY-Brake After for LT20 Drum, Ferode AM4 44100-M7000 CYL ASSY-Wheel 5/8" LT20 Selective Use, N10 standard 44100-M4901 CYL ASSY-Wheel 11/16" LT20 Selective Use 44100-G2800 CYL ASSY-Wheel 1/4" LT20 Selective Use 44100-U9200 CYL ASSY-Wheel 13/16" LT20 Selective Use
1984 Nissan Competition99996-H7010 1200, F10 & 310/N10 DP11 BRAKE PAD SET 44060-27720 BRAKE SHOE/FORE for 1200 and early B210 44070-27720 BRAKE SHOE AFT for 1200 and early B210 44100-H3320 5/8" WHEEL CYLINDER for 1200 and early B210 44100-H3300 11/16" WHEEL CYLINDER for 1200 and early B210 44100-H3100 13/16" WHEEL CYLINDER for 1200 and early B210
