These are important parts, oftentimes overlooked, but can have a large effect on how well the carburetor works.
Miscellaneous Carburetor Parts
- TOMCO 10002A AT w/Electric Choke $200.79, MT w/Electric Choke $204.79 USD Carburetor (remanufactured)
Choke Pull Off
- Nissan 16011-H3910
- 7248
- TOMCO 7211 (Type HI-2), A12A 1981-1982 (strait fitting) $9
- TOMCO 7213 A14 1978-1981 (80-degree fitting)
- 7281 1978-1980
- TOMCO 7386 A12A 1980 (90-degree fitting)
- TOMCO 7390 A14 1975-1978 (90-degree fitting) $8
Anti-Diesel valve
- TOMCO 8134 $36
- Chevy Luv Truck 1975-1980
- Ford Courier Truck 1979-1980
- Honda 1973-1976
- Mazda 1975-1978
- Datsun 1973-1983
- Subaru 1974-1980
Late Model A12 carburetor gasket
Gaskets
Part Numbers, B110
B110 RAW LIST 16010-H1601 ASSY-CARBURETOR (HITACHI DCG 16010-H1602 ASSY-CARBURETOR (HITACHI DCG 16010-H1600 ASSY-CARBURETOR (HITACHI) 16118-H1000 ASSY-CHAMBER THROTTLE 16145-91460 SPRING IDLER ADJUST SCREW 16145-50000 SPRING THROTTLE ADJUST SCREW 16129-14811 SCREW-THROTTLE ADJUST 16129-25715 SCREW THROTTLE ADJUST 16144-B0815 SCREW IDLE ADJUST 16082-18010 PLATE-ADJUST 16065-10620 SCREW 6D 16065-H1010 SCREW 6D 16029-18010 WASHER 6D 16061-18010 FLOAT 16066-18010 SHAFT FLOAT 16101-H1000 VALVE NEEDLE 16094-10400 WASHER 10D 16098-25710 FILTER 16025-H1000 TUBE EMULSION (P) 16026-25710 TUBE EMULSION (S) 16026-B0810 TUBE EMULSION (S) 16171-25710 WEIGHT INJECTOR 16033-18017 JET-MAIN #92(2000M) 16034-18016 JET-MAIN #86(4000M) 16034-19915 JET MAIN #98 16135-33815 JET MAIN #135 16050-18010 BLEED MAIN AIR #80 16204-08000 BLEED MAIN AIR #100 16213-08000 BLEED MAIN AIR #220 16052-85060 BLEED MAIN AIR #200 16055-14811 JET SLOW #43 16054-B0810 JET SLOW #50 16059-14810 VALVE POWER #60 16455-H1000 KIT-GASKET 16455-H6200 KIT-GASKET 16465-H1000 SCREW & WASHER ETE KIT (A) 16475-H1000 SCREW & WASHER ETE KIT (B) 16134-18010 LEVER THROTTLE 16116-18010 SLEEVE 16133-H1000 LEVER STARTING 16084-58000 WASHER 16084-22010 WASHER 16160-H1001 SPRING-THROTTLE RETURN (FOR 16010-H 16160-H1000 SPRING THROTTLE RETURN 16141-18010 ROD CONNECTING 16272-36710 PLATE DRAIN 16151-H1000 PISTON 16148-H1000 SPRING PISTON RETURN 16307-04000 COVER PUMP 16302-18010 LEVER PUMP 16305-19915 SHAFT PUMP LEVER 16143-18010 ROD PUMP 16011-H1600 ASSY-CHOKE CHAMBER 16011-H1601 ASSY-CHOKE CHAMBER 16248-H1000 ROD CHOKE CONNECTING 16161-H1000 HANGER SPRING 16161-H1001 HANGER-SPRING 16155-B0815 ARM THROTTLE WIRE 16165-H1600 ARM CHOKE WIRE XX010-H1925 KIT-REPAIR A 16009-H1910 KIT-REPAIR A CARBURETOR 16009-H7000 KIT-REPAIR A CARBURETOR 16009-H6200 KIT-REPAIR A CARBURETOR X6010-H1925 KIT-REPAIR A 16009-H1911 KIT-REPAIR B CARBURETOR X6010-H1926 KIT-REPAIR B XX010-H1926 KIT-REPAIR B
