Engine Bay
Revision as of 07:50, 23 August 2016; view current revision
Category: Engine Bay
The Datsun 1200 has a small Engine Compartment — as is fitting for its optimized lightweight design. Yet still there is plenty of room for maintenance. Nissan calls it the engine room and many people call it the engine bay.
ID
B10 (quick ID: No strut towers)
6477.jpgAlbum 6477
B110 (quick ID: bonnet seal is above the wiper motor)
1759.jpgAlbum 1759
B210 (quick ID: bonnet seal is below the wiper motor)
17200.jpgAlbum 17200
B310 (quick ID: bonnet seal is low and nearly flat)
7330.jpgAlbum 7330
Measurements
Approximate measurements follow. They are hand measured, so the accuracy is fair, but the precision is questionable.
  • 36.5": Width between Strut shafts at top
  • 30.75": Width between strut tower faces at A12 rocker cover height
  • 26.25": Length from firewall to radiator mounting surface
    Firewall measured behind engine, above the tunnel
  • 27.12": Length from core support header to firewall
    firewall measured at raised boss
  • Width between subframe rail faces:
Comparision
B10 (Datsun 1000)
4240.jpgAlbum 4240
B110 (Datsun 1200)
374.jpgAlbum 374
B210 (Datsun 120Y/140Y/Sunny)
B310 (Datsun Sunny/210/120Y/130Y/140Y/150Y)
220.JPGAlbum 220
Bay Lower Cover
For aerodynamics.
 See Main Article: Dust Pan
B10 (Datsun 1000) more photos
4240.jpgAlbum click to view 6477.jpgAlbum click to view
B110 (Datsun 1200) more photos
374.jpgAlbum click to view 1759.jpgAlbum click to view 374.jpgAlbum click to view 10463.jpgAlbum click to view 17910.jpgAlbum click to view 25782.jpgAlbum click to view 25785.jpgAlbum click to view 14608.jpgAlbum click to view 5123.jpgAlbum click to view
3131.jpgAlbum click to view 17200.jpgAlbum click to view 25454.jpgAlbum click to view
B310 Sunny/210
220.JPGAlbum click to view 6800.jpgAlbum click to view 7330.jpgAlbum click to view
