Console
Revision as of 22:27, 28 September 2018; view current revision
Categories: Interior | Fibreglass
Datsun 1200s were fitted with various consoles including full-style and compact style.
Full Size
Full size console was usually fitted with a Clock. The Tachometer was rightly fitted into the dashboard, but you can put the tachometer in the console if you so choose.
0570589A30151217W00410.jpg 0570589A30151217W00410.jpg 0570589A30151217W00404.jpg
5703.jpgAlbum click to view 21473.jpgAlbum click to view
12526_4fe135ad71545.jpgUpload click to view
Heater vents still work even with the console in place
26272.jpgAlbum 26272
21477.jpgAlbum click to view Foam block on underside 14949.jpgAlbum click to view
21478.jpgAlbum click to view Brackets
592.jpgAlbum click to view w/o heater
6595.jpgAlbum click to view SSS
1970-1971 appears to be gold tinted, while 1972 seems to be silver-tinted. But the GL brochure shows what looks like a black tinted console. The catalogs show only two numbers: early and 1972.
gsi.jpg GL 460.jpgAlbum click to view GX Facelift
25955.jpgAlbum click to view lc1.jpg lc2.jpg lc3.jpg lc4.jpg lc5.jpg lc6.jpg lc7.jpg lc8.jpg lc9.jpg lca.jpg lcb.jpg lcc.jpg
25970.jpgAlbum 25970 25969.jpgAlbum click to view 25971.jpgAlbum click to view
Bracket tabs are hot air deflectors
Consoles assemblies come with Clock mask, Clock is sold separately.
Sunny 1200 Optional Parts catalog
* 74980-H2010 ASS'Y-CONSOLE BOX (大型 large type) GL/GX manual
* 74980-H2020 ASS'Y-CONSOLE BOX (大型 large type) GL automatic
Japan catalog
1972 Japan [Facelift] catalog
* 74980-H3320 CONSOLE BOX ASS'Y-with bracket GL/GX 4-speed
* 74980-H3330 CONSOLE BOX ASS'Y-with bracket GL automatic
USA Catalog
* 74980-H1801 ASSY-BOX CONSOLE MANUAL -0772
* 74980-H2010 ASSY-BOX CONSOLE COUPE MANUAL 0772-
* 74980-H7000, 74980-H7001 ASSY-BOX CONSOLE MANUAL 0772-
Mask
Console mask starts with the same plastic piece as the dash mask, and then rivits it to a complex aluminum adapter.
'Sunny'
74990-H2021 MASK-clock [console]
23452.jpgAlbum click to view
'Datsun'
74990-H1800 MASK-CLOCK [console]
25956.jpgAlbum click to view
Compare to simpler Dash blank
23442.jpgAlbum click to view
The console mask has an aluminum adapter bracket to allow it to bolt to the three console holes.
25961.jpgAlbum click to view 25960.jpgAlbum click to view
Clock Fitting
Just unbolt the mask plate, and bolt in the Clock. The same clock fitted in the dash is used in the console.
The second set of tabs - back from the face - are used to bolt into the console
click
lc9.jpg 21465.jpgAlbum click to view 21466.jpgAlbum click to view
If the side-brackets are missing - e.g. a 1976-up Truck clock - you may fabricate a simple bracket to hold the clock in place.
discussion
27389-H2300 SPACER-rubber (fixing clock to console box)
25962.jpgAlbum 25962  post
If you buy a second-hand clock and end up with the Facelift clock, cut the long bracket off to make it fit in the console:
click
24043-H2000 ASS'Y-CABLE, for console clock GX [extension harness for clock wiring]
Fibreglas
Glassfibre versions
7955.jpgAlbum click to view 7956.jpgAlbum click to view 14774.jpgAlbum click to view 14775.jpgAlbum click to view 14776.jpgAlbum click to view 14777.jpgAlbum click to view 16616.jpgAlbum click to view
Short Console
0706654A30140606W00210.jpg 10456.jpgAlbum 10456
The short pocket-type console was fitted to:
* Automatic DX
* OPTION 4-speed 1200s STD and DX
* JAPAN 3-speed column shift OPTION
* B120 Pickups as standard equipment (except STD models)
13667.jpgAlbum click to view 1970-1978 (Black) 21470.jpgAlbum click to view
16086.jpgAlbum click to view 1978-1989 (Brown) 16664.jpgAlbum click to view
16654.jpgAlbum click to view 1989-1995 (Gray) 21468.jpgAlbum click to view 21469.jpgAlbum click to view
Brackets (B122 pictured)
74987-H1801 BRACKET-CONSOLE FRONT [long bracket]
74988-G1161 BRACKET-CONSOLE [rear, short bracket]
01241-00061 NUT (4)
08510-61697 SCREW (holding console to bracket)
08510-61642 SCREW (holding bracket to floor)
Automatic
20399.jpgAlbum 20399
Floor Trim Part Numbers
* G4980-H1025 ASS'Y-CONSOLE BOX [short, OPTION for 3-speed (column shift)]
Japan CONSOLE BOX
* 74980-H1801 ASS'Y-CONSOLE BOX, 小型 (small type) with bracket 4-speed (ex. GL, GX)
* 74980-H1021 ASS'Y-CONSOLE BOX, 小型 (small type) with bracket A-all (ex. GL)
North America
* 74980-H1921 ASSY-BOX CONSOL SEDAN,COUPE AUTOMATIC
* 74980-H1801 ASSY-BOX CONSOL SEDAN,COUPE MANUAL OPTION
* 74980-H7000 ASSY-BOX CONSOL SEDAN,COUPE MANUAL OPTION 0772- [Fire-resistant?]
B120
* 74980-H1801 CONSOLE BOX KIT-FLOOR W/BRACKET     -7803 [Black]
* 74980-G1160 CONSOLE BOX KIT-FLOOR W/BRACKET 7804-7907 DARK BROWN
* 74980-G1660 CONSOLE BOX KIT-FLOOR W/BRACKET 7908-8109 BROWN
* 74980-G1900 CONSOLE BOX KIT-FLOOR W/BRACKET 8110-8910 [revised finisher panel]
* 96910-95W00 CONSOLE BOX KIT-FLOOR W/BRACKET 8910- GRAY
Shifter Boot
シフト ブーツ Boot for shift lever. Full and short consoles use the same boot.
Aftermarket
25546.jpgAlbum 25546
Nissan
Buy from Bprojects
BOOT
74986-H1801 ASSY-BOOT MANUAL [Black] -7803
74986-H7000 ASSY-BOOT MANUAL 0772- USA [Black Fireproof?]
74896-G1160 7804-7907 [Dark Brown]
74896-G1660 7908-8910 [Brown]
96935-95W00 8910- [Gray]
Finisher
08961-13240 NUT (4) (holding finisher to console)
74982-H1021 FINISHER-CONSOL BOX AUTOMATIC
74982-H1801 FINISHER-CONSOL BOX MANUAL -8109
74982-G1900 PANEL-CONSOLE A 8110-8910
96930-95W00 PANEL-CONSOLE A 8910-
Fibreglas
Glassfibre versions
Aftermarket
Amco aftermarket/dealer installed
7450.jpgAlbum 7450 689.jpgAlbum 689
Westel docking-type 70 Console Custom (click for more photos)
174_5a19d27b9b097.jpgPost 486799 174_5a19d292ef7d4.jpgPost 486799
Long style
14598.jpgAlbum 14598
customized?
174_564aac18729eb.jpgPost 473777
EC 4420N (was spotted on eBay out of Austria)
Custom
aftermarket gauges fitted
3069.jpgAlbum 3069
3189.jpgAlbum 3189 16671.jpgAlbum 16671 16672.jpgAlbum 16672
Português 1200s. Eles são consoles personalizados? Ou o equipamento padrão Entreposto
Portugal 1200s. Are they custom consoles? Or the standard Entreposto equipment?
804.jpgAlbum 804 1451.jpgAlbum 1451
Documentation
1555.jpgAlbum click to view JDM 2209.jpgAlbum click to view USA
18381.jpgAlbum click to view
Alternative Sources
Honda Civic
Barina
6025.jpgAlbum click to view
Barina
2970.jpgAlbum click to view
PB110
Sunny Excellent used consoles the similar to B110, but extend up further with vents that drop down in the top. Also extends further back under the handbrake lever.
9020.jpgAlbum 9020 9021.jpgAlbum 9021
  • Console could be had without any gauges (just a Sunny plate)
  • Clock with cubbyhole below was optional
  • Clock with two small gauges was optional
  • Has heater vent extender with directional (!) vents
2010.jpgAlbum 2010
* With option Large Clock
* With option auxliary gauges
  * Oil P (oil pressure) measured from 0-6 kg/cm3
  * AMP (ammeter) from -30 to +30
A. DX 'Sunny' plate
B. GL/GX Clock with cubbyhole
C. OPTION Clock with oil & AMP gauges
Gold-tint or Silver-tint
7712.jpgAlbum 7712
BOX ASS'Y-console
74980-H2501 (black) DX
74980-H2601 (black) GL
74980-H2602 (blue)  GL
74980-H2701 (black) GX
74980-H2702 (brown) GX
* Also available in DX AUTO and GL AUTO versions
* Colors are on the Finisher and the vent Louvers
MASK-console box body
コンソール ボックス ボヂー マスク
74982-H2501 DX    'Sunny'
74982-H2600 GL,GX [clock]
74982-H2601 OP.   [gauges]
74990-H2600 MASK ASS'Y-clock
27380-H2600 CLOCK ASS'Y [same as PB110 dash clock]
DX MASK - 'Sunny' clock blank
3099.jpgAlbum 3099
GL/GX MASK - Clock with cubbyhole
21465.jpgAlbum 21465 21464.jpgAlbum 21464
OPTION MASK - Clock with Gauges
21474.jpgAlbum 21474 23441.jpgAlbum 23441 21476.jpgAlbum 21476 21475.jpgAlbum 21475
B210 Console
Does not fit the 1200 well
A12/A14/L14
H50 DX,V  short type
H51 GL,GX long type
L16
H59 GB210 black or brown
* with coin tray
* with pocket
* with clock B210
* with twin gauges B210 or PB210
Short B210
3146.jpgAlbum 3146 2858.jpgAlbum 2858
74598-H5000
Long B210
Standard for GX & GL, Option for DX & Van
Modified for use with shifter of long gearbox
This one has been cut to shorten it?
B310 Console
Sold by Bprojects
96935-H8500 BOOT (BLACK)(G) <> 96935-H8560 $35.58 USD
96935-H9160 BOOT (BLUE) 0879- $32.62 USD
96935-H9100 BOOT (BLUE) -0779 $30.12 USD
96935-H8561 BOOT (BROWN) $35.58 USD
838.jpgAlbum click to view 1350.jpgAlbum click to view 834.jpgAlbum click to view 4748.jpgAlbum click to view 4823.jpgAlbum click to view 4939.jpgAlbum click to view 5619.jpgAlbum click to view 9471.jpgAlbum click to view 19640.jpgAlbum click to view 21466.jpgAlbum click to view 21467.jpgAlbum click to view 21471.jpgAlbum click to view 21472.jpgAlbum click to view
click
click
keywords: コンソール
