Adapter Hubs for aftermarket steering wheels. These hubs bolt to the Datsun 1200 steering column and allow for using many brands of steering wheels.
Only a few Datsun models used the small diameter steering column shaft, including the B10, B110 & B210. The B10 used blinker canceling pins that were relatively close together & this made it unique. The B110 & B210 share the same specs so the hub/boss is interchangeable between these two models.
Most other Datsun models, including the B310, used a larger diameter shaft & the boss for any of these will be too big in the hole to fit the 1200.
Conpatible
- 1970-1973 B110 Datsun Sunny 1200
- 1973-1978 B210 Datsun Sunny B210/120Y
- 1977-1979 S10 Datsun 200SX/Nissan Silvia
- 1970-1977 C120 Vanette/Sunny Cab
- 1978-1982 N10 Datsun 310/Nissan Pulsar
Wheel Bolt Patterns
Other than a boss that bolts to the 1200 column, consider which Steering Wheels it bolts to:
- 3 x 1.75" PCD: APC, Superior, Grant
- 6 x 2.75" PCD: Grant (close enough to use with many 6x70mm wheels)
- 6 x 70mm PCD: Momo, SPW, Netami, Sparco, Mugen, NRG, OMP
- 6 x 70mm rotated: Grip Royal
- 6 x 74mm PCD (M5 bolts): Nardi, Personal
- 6 x 74mm PCD (M6 bolts): RAID, Dino, Gussi Italia
Adapters are 10mm to 14mm thick and cost $20-$40 USD.
Grant to Momo steering wheel adapterᴳ
For Nardi and Personal (74mm PCD) wheels, a thin adapterᴳ can be used to bolt to a 70mm boss. It also rotates the wheel so it will be positioned correctly.
Nardi to Momo steering wheel adapterᴳ
Horn
Horn contact in the steering column rides on the bottom side of the hub
With two-wire Horn Button:
- earth wire
- Horn trigger wire
With single-wire Horn Button
- earthed via the screws/fasteners
- Horn trigger wire
Three-bolt Steering Wheels
4590
Grant 4590 steering wheel installation kit (adapter hub a.k.a "boss kit") will work with APC, Superior, and Grant 3-bolt steering wheels. It has a die-cast hub adapter and horn button (with spring), Grade 5 bolts. Fits all Grant Classic Series, Challenger Series and Signature Series Steering Wheels. Use the cancel roll-pins from the original wheel.
Grant 4590ᴳ
NOTE: As of January 2012, there are a rash of reportsᴳ that the latest Grant 4590 model sold on eBay does not fit the 1200.
The old Grant 4590 DOES fit. And presumably the version sold by Grant and other major retailers does too.
Grant no. 4590 fits * 1976-78 F10 * 1979-82 310 * 1974-78 B210 * 1971-73 1200 $39 Manufacturer's Suggested List Price (2021) $36 Summit Racing (2021) $37 Jegs (2021)
Post Cover (adapter/column cover) available in: * Matte Black * Chrome (optional)![]()
No. 470-3592 does *not* fit the 1200, but fits: * 1970-83 240Z,260Z 280Z * 1978-85 Nissan pickup * 1980-83 Nissan SX200 * 1979-83 Datsun B310 * 1973-75 Datsun 610 * 1974-75 Datsun 710
Grant 3-bolt to 6-bolt adapterᴳ
Six-bolt Steering Wheels
Personal
Kit Personal for B110 (1200) & B210 (120Y)
MOMO
MOMO boss kits will fit all Steering Wheels with 6 x 70mm (approx. 2.75") bolt pattern (such as MOMO, SPW, Netami, Sparco, Mugen ... etc), about2-6/8" distance between center of both opposite screw holes.
MOMO No. 3504 fits:
* B110 (1200)
* B210 (120Y)
MOMO No. 3503 fits: * Datsun 240Z, 260Z, 280Z, 280ZX, * Datsun 510, 610, 810 all yrs * Datsun/Nissan Trucks up to 1986
Generic
$30 including shipping off eBay
Multi-pattern Boss
SAAS boss kits suit most sports wheels Including, Saas, Autotecnica, MOMO, Boss, Victor, Oba, Rspeed, and more.
SAAS 13-BK71L 120Y (B210) 13-BK7BL 1200 (B110) 13-BK8AL B310,510,610,810,910 13-BK8AL 260C 13-BK8BL 240Z, 260Z 13-BK112L 280ZX 13-BK144L 300ZX Australia del. only
Slim Boss Kits
Short boss kits are totally worth it to maximize steering wheel to body distance.
Randoli: i got a boss kit (HKB Sports made in Japan) through disco bob (look him up on this site)and it was about 12mm shorter than the previous one. i find now my knuckles sometimes flick the indicator stalk. i'm 6'2" and the reach is perfect in a standard seat. so how short is too short
Slightly bend the indicator stalk to the right position. Ring spanner slid down a 1/4 and bend.
Alternatively, consider using a wheel with 'spokes' that are relatively flat, so they don't space the bolt surface back further. Then a regular size hub can be used while still keeping the wheel close to the dash.
Datskool110
datskool110 designed a low-profile boss and was making kits POST and selling on eBay (2013)
Wardman
Wardman Engineering can custom machine any boss you would like , short , long , big ,small , but they are custom made from billet 6061-t6 so they are a bit more expensive than eBay specials, but you will have the best one for your application discussion
From $150
